-   -   Compressor while running heat (http://www.diychatroom.com/f17/compressor-while-running-heat-157605/)
columbiawifi 09-22-2012 09:35 AM
Kind of a dumb question here.
I have a contactor that is stuck in the open/on position. I've ordered my replacement and in the meantime I am just running the ac as needed. When I turn he air off I switch the inside breaker to the compressor off. That way it doesn't run without the air handler and freeze up.
Its starting to get cold this weekened. If I need to turn the heat on, do I need to make sure the compressor runs with it? It doesn't..does it? Compressor is just for A/C?
This is a small carrier unit. Air handler in the attic, condenser outside, gas heat.
thanks
hvactech126 09-22-2012 12:39 PM
compressor is just for a/c unless you have a Heat Pump. It does not sound like you have a heat pump though.
