Old 06-29-2009, 10:27 PM   #1
compressor size
Can someone give me the btu rating of this compressor?
Copeland
CRH3-0275-PFV
I believe it is a 30k btu (2.5 ton) compressor. I just wanted to make 100 percent sure.
pomelo is offline   Reply With Quote
Old 06-29-2009, 10:31 PM   #2
GC/Master Plumber/Mech
compressor size
I'm thinking 3
There should be another number to the right of this number and just below it.. Can you post it 6 or 7 letter/numbers
Old 06-29-2009, 10:34 PM   #3
Home Air Direct's Avatar
compressor size
It has been used in a zillion 3 ton air conditioner models over the years.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-29-2009, 10:56 PM   #4
compressor size
How many btu's is this compressor? It appears to be 32k btu's. That is why I was thinking it is a 2.5 ton. It is in a 20 year old janitrol/goodman unit. I'm really not familiar with copeland nomenclature, but I think the 275 designates 2 3/4 HP.
Old 06-29-2009, 11:05 PM   #5
compressor size
2-3/4 Ton 32,700 BTU Copeland Compressor (1-Phase)
Quantity in Basket:none
Code: COMP35K6PFV
TECHNICAL SPECIFICATIONS
Nominal HP 2-3/4
BtuH 32,700
Volts 60 Hz 208/230-1.
Phase 1.
Refrigerant Type R-22.
Line Connection Suction ID (In) 3/4 .
Line Connection Discharge ID (In) 3/8.
Base Mounting Centers (In) 7 1/2 x 7 1/2.
Height (In) 14 13/16.
Width (In) 9.
Length (In) 9 7/16.
Run Amps@BtuH 17.4.
Application OEM A/C Equipments.
Includes Crankcase Heater.
Part Numbers:CAR4D667, CR37KQ-PFV-980WB.
THIS COMPRESSOR REQUIRED ACCESSORIES:
Suction Line 3/4" Filter/Dryer Part Number:FILD34SW
Liquid Line 3/8" Filter/Dryer Part Number:FILD38SW.
Replaces Part Number:GP373-GG1-A, CR37KQ-PFV-980WB, CRH3-0275-PFV-230, CRK3-0325-PFV, CRK3-0325-PFV-230, CR35K6-PFV-270, CARCRK30325PFV
Old 06-30-2009, 07:06 AM   #6
An old Tradesmen
compressor size
The CR34KQ-PFV may be a closer match to the CRH3-0275-PFV
34,000BTUs at 115° Condensing temp, 43,800BTUs at 100° condensing temp.
