Old 07-27-2011, 08:30 PM   #1
Compressor running hot
HI I AM WORKING ON A CARRIER 30TON SEMI HERMETIC using R22 - I had a problem where the reed on the center head brok and they the piston/rod broks
After reassembling I am only getting 150psi, and the head is VERY hot, changed driers, pressure release valves, bearings
any help
jefe is offline   Reply With Quote
Tags
hot ccompressor
