Compressor Overheats After 5 Minutes - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 05:38 PM   #1
Question
Compressor overheats after 5 minutes
I have a window a/c unit that stopped working. The fan only hummed. I replaced the capacitor and then the unit starts normally, but after about 5 minutes the compressor shuts down, apparently due to overheating. The fan continues to run. It takes about 15 minutes for the compressor to cool down and reset. I was thinking low on refridgerant, but the compressor does not freeze up, but rather heats up. When the unit is first turned on it has cold air blowing.
hillbillybill is offline   Reply With Quote
Old 07-07-2011, 05:51 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
did you take it to the car wash and flush out the outer condensor coil and check the inside one for dirt. slide the cover off like a sleeve to get at the internals.it needs freon to cool the compressor and if low then it will overheat.it may cool for a few mins then eventually overheat the compressor.
The ceiling lights go out after 10 minutes pghdude2480 Electrical 6 06-30-2011 10:15 PM
sump pump keeps tripping breaker after about 5 minutes of running DanDaMan Electrical 9 04-22-2011 12:32 AM
Carrier Heater cutting off after a few minutes (pictures and video) HELP.. -cooold- delawareIT HVAC 23 01-03-2011 05:30 PM
my central a/c heat unit trips my 40 amp breaker after running heat for 5 minutes. buttons1 Electrical 2 12-27-2010 10:23 AM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 01:31 PM
