Compressor Not Running... Buy New Or Used? - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 10:22 PM   #46
JJboy's Avatar
Originally Posted by tgillespie View Post
Any idea of what to say or do next? Also, do you have a link or reference that I can use to tell the tech the ohms readings are fine?
There are 2 more test. 1- continuity test C/R/S to ground
2- Megger test C/R/S to ground
Need to check high/low pressure switch
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-24-2011, 10:54 PM   #47
REP
JUST A note HERE.BUYING A USED COMPRESSOR IS LIKE BUYING AN OLD YUGO WITH A MISSING KEY.DON'T PUMP TOO HARD TO THE FLOORBOARDS TO TRY AND GET IT STARTED.
REP is offline   Reply With Quote
Old 07-25-2011, 01:16 AM   #48
I think I may have an idea oh what might be causing an issue.
The original compressor was single phase. The new compressor is three phase. The only thing I don't get is his ohm readings... as they look reminisent of a single phase.
A few questions...
If the tech hooked the 3 phase compressor up to single phase power, is the motor shot?
Wouldn't a 3 phase compressor give ohm readings that are the same across the board? C-S, C-R, R-S all equal each other?
tgillespie is offline   Reply With Quote
Old 07-25-2011, 01:29 AM   #49
JJboy's Avatar
It's difficult to say. But any reading under 5 ohms the compressor should be ok. Also the math should match: (C-R) + (C-S) = (S-R)
Old 07-25-2011, 01:34 AM   #50
I thought ((C-R) + (C-S) = (S-R)) was for phase 1? And on phase 3, they all were the same?
Old 07-25-2011, 01:46 AM   #51
JJboy's Avatar
3 phase you have the same values between two wires.
Old 07-25-2011, 01:50 AM   #52
Wow. Well, tomorrow is going to be a pretty sad phone call. I double checked with the HVAC installer with the URL to the compressor. He never mentioned that a phase 3 wouldn't work. Partially my fault, but partially his. Especially since he installed and tested without mentioning a thing.
You live and you learn I guess.
Sound of Water Running in Pipes rpishotti Plumbing 4 12-06-2010 01:09 AM
Basement *VENTING* AND running entire new drain lines. 57_Hemi Plumbing 6 09-30-2010 10:00 PM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 10:13 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 08:03 AM
