Old 07-11-2011, 07:00 PM   #1
Compressor not running... buy new or used?
AC unit in my house isn't getting cold, so after some reading and troublshooting, I've discovered...
  • Evaporator is clean.
  • Furnance filter clean.
  • Thermostat works.
  • Cooling fan works.
The pipes going in/out of the house are not hot/cold and I cannot hear the compressor kick on. So my question is, whats the best way to go replacing/repairing it?
I don't want to spend a bunch of money as we wont be in the house for much more than a year or 2.
tgillespie is offline   Reply With Quote
Old 07-11-2011, 07:01 PM   #2
Also, if I get a new compressor, are you able to put a 3.5 ton compressor on a 3.0 ton system?
Old 07-11-2011, 07:08 PM   #3
By cooling fan works, do you mean the one outside?
Artco is offline   Reply With Quote
Old 07-11-2011, 07:10 PM   #4
Have continuity between the compressor terminals or not? If not is the compressor hot to the touch? If yes list the ohm readings. Capacitor rated for what mfd and what does it test at? Compressor wires all in tact or are one or more burnt off?
I would NEVER buy a used compressor.
Old 07-11-2011, 07:12 PM   #5
Yes the one outside.
Old 07-11-2011, 07:15 PM   #6
Hvac Pro
NO. Why jump to conclusions. How old is the unit. May just need a simple capacitor. Post brand, model and serial # and we may be able to tell it's age.
The Following User Says Thank You to yuri For This Useful Post:
tgillespie (07-11-2011)
Old 07-11-2011, 07:16 PM   #7
Be right back.
Old 07-11-2011, 07:22 PM   #8
Bristol
Model Number: H29B35UABCA OC-25
Part: 709012-1501-00
V: 230/208
Hz 60 PH1
LRA 86
Old 07-11-2011, 07:26 PM   #9
Hvac Pro
Bristol makes compressors not complete ACs that I know of. Need the info from the name plate of the outdoor unit.
Old 07-11-2011, 07:29 PM   #10
JJboy's Avatar
Thermostat is calling for cool?
One dual capacitor or 2 capacitors
Outside fan is working?
Have you check the contactor? high voltage
Are you getting 24vac at the contactor ( low voltage )
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-11-2011, 07:30 PM   #11
That was from the compressor.
The actual AC Unit is a Goodman CKL36-1D Series
Old 07-11-2011, 07:31 PM   #12
Hvac Pro
should be a serial # below it.
Old 07-11-2011, 07:34 PM   #13
Originally Posted by JJboy View Post
  1. Thermostat is calling for cool?
  2. One dual capacitor or 2 capacitors
  3. Outside fan is working?
  4. Have you check the contactor? high voltage
  5. Are you getting 24vac at the contactor ( low voltage )
  1. yes
  2. Don't know. What do I look for here?
  3. yes
  4. yes
  5. yes
Old 07-11-2011, 07:36 PM   #14
JJboy's Avatar
  1. yes
  3. yes
  4. yes
  5. yes
Disconnect the power. open the electrical box at outside unit. you should see 1 or 2 capacitors close to the contactor. Can you post a pic.
Old 07-11-2011, 07:38 PM   #15
Serial: 0105433408
Sound of Water Running in Pipes rpishotti Plumbing 4 12-06-2010 01:09 AM
Basement *VENTING* AND running entire new drain lines. 57_Hemi Plumbing 6 09-30-2010 10:00 PM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 10:13 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 08:03 AM
