Compressor Never Shuts Off - HVAC - DIY Chatroom Home Improvement Forum
Old 08-14-2012, 01:35 PM   #1
Compressor never shuts off
So we had a new air handler and a new condenser put in. Since then the compressor never shuts off, and the AC runs a lot cooler than the thermostat is set to. With the thermostat set to 72, one room is as cold as about 58.
I don't expect anyone to be able to help with such limited information, but how bad is it to have the compressor constantly on? (I'm assuming it's on because the fan is constantly running, and because it's so cold). How long is too long to run it this way?
PM5K is offline   Reply With Quote
Old 08-14-2012, 01:41 PM   #2
Rewards Points: 14,306
Why are you just dealing with it? Call them back to fix it asap.
Old 08-14-2012, 02:45 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Compressor consistently running to me means a stuck contactor. You said the entire condenser is new. Do you mean the entire system is running well below desired set point? Are you sure both the inside and the outside units are running and again, after desired set point?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-14-2012, 03:19 PM   #4
I think he means that one room is very cold and the other room won't meet the temperature on the thermostat.
OP, turn the temperature up.
option12 is offline   Reply With Quote
Old 08-14-2012, 08:07 PM   #5
The entire system is running colder than it should. In the morning the difference between the set point on the thermostat and the coldest room is 58-59 to a set temp of 72.
Old 08-14-2012, 08:21 PM   #6
Rewards Points: 616
you have a problem.... a/c is not stopping..... costing you money and you need blankets,,, get it fixed
carmon is offline   Reply With Quote
Old 08-14-2012, 09:00 PM   #7
I know I have a problem, just wondering how bad it is for the comp to run continuously and how long it can take it.
Briandl is offline   Reply With Quote
Old 08-14-2012, 09:03 PM   #8
Rewards Points: 271
Why not call the contractor back out to the house?
FrankL is offline   Reply With Quote
Old 08-14-2012, 09:05 PM   #9
Missouri Bound's Avatar
It will definetely shorten it's life....but your concern is better placed at fixing the problem. You have a wiring problem (most likely) or a bad thermostat. It's stupid for you to worry about the compressor when it's not the real issue here.
Do you want it your way or the right way?
Old 08-14-2012, 09:11 PM   #10
Rewards Points: 582
call back the installing company..something is wrong..and yes it could be damaging to the system.. don't wait..
Old 08-14-2012, 09:26 PM   #11
Sounds like the control wiring is miswired.
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
Missouri Bound (08-14-2012)
Old 08-14-2012, 09:39 PM   #12
If I have people telling me I need someone out asap before the compressor gets damaged, that carries more weight than saying my house is too cold.
If you know what I mean.
Old 08-14-2012, 09:44 PM   #13
Why don't you just turn it off?
Old 08-14-2012, 09:51 PM   #14
Yep turn the breaker to the AC off.
Condensor fan shuts off after exaclty 10 miutes KP616 HVAC 5 08-07-2012 10:39 AM
Heil furnace gas shut's off & on mkmoony HVAC 5 12-17-2011 07:20 AM
Electrical Problem w/ New AC Blower Motors - High Speed shuts off after 15 Min? Tyndale Electrical 6 07-10-2011 03:58 AM
water pressure no staying after pump shuts off mjrosa Plumbing 3 03-20-2011 10:09 PM
Gas Furnace Shuts off and doesn't turn back on jamesd HVAC 6 03-22-2009 06:45 PM
