Compressor Kicks In For A Few Seconds Then Shuts Off - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2010, 02:15 PM   #1
Compressor kicks in for a few seconds then shuts off
Both fans run continuously , I hear the compressor turning on for about 3 seconds then shuts off...this cycles about every 5 minutes . I'm told I need a new unit. Also since it's an older lennox, using r22, I'll need to replace the coil in the furnace? anyway to fix it?...Thanks
ron826 is offline   Reply With Quote
Old 07-01-2010, 02:58 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
What is the model and serial # of the outdoor unit? It may be low on freon and cycling on the low pressure control.
Old 07-01-2010, 04:05 PM   #3
it's a lennox hs18-411-69...thanks
Old 07-01-2010, 04:19 PM   #4
An old Tradesmen
Rewards Points: 7,278
Did you get a second opinion yet?
Yuri will know more about that unit them me though. So follow his advise.
Old 07-01-2010, 04:40 PM   #5
Hvac Pro
yuri's Avatar
That is an OLD unit circa 1983. No low pressure control. Probably the compressor is seized up and cutting out on the internal overload. Only about 10% of the era of unit left running. Mostly the compressors wear out and seize after 25 yrs. I would replace it and the indoor coil as it is a 8 SEER and incompatible with the higher SEER newer units. Pretty good stuff that Lennox if it lasted that long.
The XC series they have now is VERY good.
That is a 32,000 BTU unit=a bit more than 2.5 tons. You may need a 3 ton unit. I would do a heat load calculation to make sure you get the right sized unit:Load Calculator
Old 07-03-2010, 04:31 AM   #6
Thanks for the help...always good to get a second opinion . Problem is I dont have the $2500 to replace the unit right now, and I need to get the house on the market.
Old 07-03-2010, 05:15 AM   #7
An old Tradesmen
Lots of houses don't sell well without a working A/C.
You could always knock off 5000 to 7500 bucks on your asking price. To allow the new owners to replace the system after they buy it. A good HVAC company will sell them a proper matching system.
Gas furnace stays on 1 minute then shuts off -- any troubleshooting help? Endzone HVAC 2 10-23-2009 11:41 PM
Boiler starts for 10 seconds, then shuts off Mark 40 HVAC 3 08-31-2009 02:14 PM
Lennox Heatpump shuts off after about 20 seconds dmanmtl HVAC 4 02-23-2009 08:03 AM
A/C only shuts of few a few seconds... KKelsey HVAC 4 08-09-2008 11:08 AM
furnace cycles, runs for 45-60 seconds shuts down and recycles again ronsmoneypit HVAC 4 02-03-2008 01:46 PM
