Compressor Info For A Carrier 24abr330a310 Condensor - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 05:04 PM   #1
compressor info for a carrier 24abr330a310 condensor
caroea02 is offline   Reply With Quote
Old 12-08-2011, 05:11 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,440
can you be a bit more specific what you want?
Old 12-08-2011, 05:15 PM   #3
i need a compressor for this unit its a 3 ton. i have no info for a replacement comp. or what will fit.
Old 12-08-2011, 05:19 PM   #4
Hvac Pro
yuri's Avatar
why do you need it and are you a tech? not a DIY job. did it burn out or why do you need one. Carrier can get you the right one with the model #.
Old 12-08-2011, 05:25 PM   #5
i'm a student. friend gave me his units info. a carrier tech told him he had a burn out. i have not seen the unit yet just wanted info so i can shop for a comp. online or at a supply house tomorrow. i will check before i buy one but it will save me great deal pricing a comp. if that is the issue.
Old 12-08-2011, 05:32 PM   #6
Hvac Pro
yuri's Avatar
have U ever changed one? if it has burnt out then you need to decontaminate the system with a flush kit and add suction and liquid line filter driers and find out why it burnt out. not an easy job. if not done properly it will last a yr and burn out again and have no warranty. metering device may be plugged from the burn out etc etc.
Old 12-08-2011, 05:34 PM   #7
tech said their was no filter dryer. i suspect it was moister in the system. do you have the info for a replacement comp.
Old 12-08-2011, 05:35 PM   #8
Hvac Pro
yuri's Avatar
no. carrier does.
The Following User Says Thank You to yuri For This Useful Post:
caroea02 (12-08-2011)
Old 12-08-2011, 05:40 PM   #9
thanks for that info. i will check for a clogged metering device and consult the teacher in the morning.
Old 12-08-2011, 05:45 PM   #10
Hvac Pro
yuri's Avatar
compressors can burn out from weak capacitors, low incoming voltage (brown outs) power surges, burnt or loose wiring on the compressor itself , low on freon, icing up etc etc so I would encourage you to find out and learn why it burnt out rather than just changing it and not learning anything. we can help you here IF you really want to learn.
Old 12-08-2011, 07:47 PM   #11
biggles's Avatar
check here might be another brand with a carrier number...scroll?rotary?..can hermetic http://www.bestbuyheatingandaircondi...sor_search.htm
Carrier 5 Ton Condensor fan running Slow. dtgibson HVAC 4 08-30-2011 11:30 PM
3 to 4 wire condensor fan wiring nuckifuts HVAC 3 07-27-2011 01:11 AM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Condensor is not starting, why not? tburk HVAC 15 08-15-2010 12:00 PM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
