Compressor/ Fan Won T Start - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 03:23 PM   #16
Originally Posted by 3 legged dog View Post
Solenoid will buzz and click on and off with power cycle. You can take the cover off the pressure control and on the left side there is a sort of metal bar. If it is pushed back then it is trying to run. You can push it back with your thumb. Just be careful. If you have a meter you can check across the terminals under the cover.
The metal bar is all the way to the left already. I checked across the terminal but there is nothing.
What could be the problem then?
nicksab is offline   Reply With Quote
Old 09-03-2011, 03:24 PM   #17
Originally Posted by beenthere View Post
Need a set of gauges to see if there is enough charge in it to start the compressor up. Then a multmeter to see f the contacts are good/ok in the pressure control. The solenoid works, thats why you hear it click and buzz.
there is 110 v coming to each wire at the pressure control but nothing is showing across the terminal
Old 09-03-2011, 05:29 PM   #18
An old Tradesmen
Rewards Points: 6,860
When closed it should have 0 volts across its terminals.
Old 09-03-2011, 09:45 PM   #19
Thank you to all for helping me with this.
I figured it out and the cooler is now working as it is supposed to.
Just for your info, one of the wire of the pressure controller was a little loose prob from transport and moving and not making contact as it is suppose to. ( I have to admit that I should have check that in the first place )
i reset it and now the compressor fires up like a charm.
Thanks again for your help
Nicolas
Old 09-04-2011, 05:12 PM   #20
MXer
3 legged dog's Avatar
Cool.
3 legged dog is offline   Reply With Quote
compressor wants to start but won't wetbar HVAC 13 06-17-2010 06:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 01:12 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 08:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 10:58 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 07:05 PM
