Compressor/ Fan Won T Start - HVAC - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 09:38 PM   #1
Compressor/ fan won t start
Hey everyone,
I hooked up my 4 door coler today but it won t start automatically.
The fans on the evaporator are running so it is fine but i get a buzzing/clicking noise from a solenoid that is right after the filter dryer. It is connected to a ranco controller wich seems to be working fine.
The compressor and fan works fine when i push the capacitor in.
Any ideas why it won t start by it self?
thank you
nicksab is offline   Reply With Quote
Old 08-31-2011, 09:42 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
because you're pushing the capacitor in and not the CONTACTOR?
you may have some type of tripped pressure switch which is cutting the call off to come on, more than likely too low on refrigerant. Or a stuck open solenoid.
Doc Holliday is offline   Reply With Quote
Old 08-31-2011, 09:53 PM   #3
An old Tradesmen
Rewards Points: 7,816
Probably low on charge.
Old 08-31-2011, 10:05 PM   #4
Thank you for correcting me about the contactor. Yes when i push them in, everything start and works normally.
There is a clicking/buzzing noise coming from the solenoid after the filter dryer. The noise stop when i disconnect it from the ranco controller.
Old 08-31-2011, 10:06 PM   #5
The charge is fine as there is no air bubble in the glass. It was working fine before the move and no line have been cut
Old 08-31-2011, 10:11 PM   #6
the buzzing noise comes from the solenoid on the left which has one wire going to a ranco controller and another one going to L2 on the the contactor.
Any ideas why it won t start by itself when switch on??
Compressor/ fan won t start-08212011052.jpg
Old 08-31-2011, 10:12 PM   #7
An old Tradesmen
If its not running, then you can't tell if the charge is fine. the sight glass is useless for checking charge, if the unit isn't running. A line could have cracked during the move, wouldn't be the fist time its happened to a unit.
The Ranco must be connected to operate the solenoid valve, thats a pump down system.
Old 08-31-2011, 10:13 PM   #8
An old Tradesmen
I thought you said it couldn't fit in your garage/building with the condenser on top of the cooler.
Old 08-31-2011, 10:17 PM   #9
I just unscrewed the whole top and then got it in in 2 pieces then put the top back on it.
Old 08-31-2011, 10:21 PM   #10
Like i said, i can turn the unit on by pushing on the contactor and it does bring the temperature down.
Regarding the ranco, i just meant the noise stop when it is disconnected from the solenoid. if everything is connected, nothing happened.
What s the best way to check every circuit? ( solenoid, ranco, pressure controller...)
Old 08-31-2011, 10:24 PM   #11
MXer
3 legged dog's Avatar
The pressure control is holding it off. It is either out of gas or that service valve on the top area of the compressor is front seated.
3 legged dog is offline   Reply With Quote
Old 08-31-2011, 10:52 PM   #12
The valve is all the way turn to the left ( counterclockwise ) so it is back seated. Can I disconnect the pressure controller and see if it start without damaging the unit?
What about the solenoid making noise?
Old 08-31-2011, 11:21 PM   #13
MXer
Solenoid will buzz and click on and off with power cycle. You can take the cover off the pressure control and on the left side there is a sort of metal bar. If it is pushed back then it is trying to run. You can push it back with your thumb. Just be careful. If you have a meter you can check across the terminals under the cover.
Old 09-01-2011, 12:34 AM   #14
Thank you. I will take a look at the pressure sensor and keep you posted.
What about the ranco? could it need to be reprogram or reset?
everything was working perfectly before they disconnected from the breakers.
Old 09-01-2011, 04:16 AM   #15
An old Tradesmen
Need a set of gauges to see if there is enough charge in it to start the compressor up. Then a multmeter to see f the contacts are good/ok in the pressure control. The solenoid works, thats why you hear it click and buzz.
compressor wants to start but won't wetbar HVAC 13 06-17-2010 06:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 01:12 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 08:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 10:58 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 07:05 PM
