-   -   Compressor fan not spinning; erratic behavior (http://www.diychatroom.com/f17/compressor-fan-not-spinning-erratic-behavior-154898/)
purduephotog 08-26-2012 12:26 PM
Good morning-
Discovered yesterday the compressor fan was not spinning but the compressor was working fine. Unfortunately by the time I figured that out the lines were quite hot.
The motor spins free and ohms out OK.
The starter cap (3/35) reads 2.73/??? (Beyond meter to read).
The contacor engages and ohms correctly.
When I reassembled the unit the fan started up fine, but 20 minutes later shut off, leaving the compressor running.
Suggestions where to go from here?
Motor is Emerson k55hxhdd 8562
Cap is hq1086679AX
JJboy 08-26-2012 01:53 PM
recheck the dual capacitor
purduephotog 08-26-2012 01:58 PM
Thanks. I'll have to wait a day to get it into the lab.
reassembled the unit fired right up. This time I stood next to it and waited. Eventually the fan slowed and the braked to a stop. Fan was somewhat stiff to turn compared to earlier. Measured case temp of fan with non contact ir thermometer and got 202f. Pulled the disconnect instead of testing for voltage on fan. Relay was still engaged.
beenthere 08-26-2012 04:44 PM
Probably weak electrical insulation in motor.
purduephotog 08-26-2012 07:54 PM
In other words, replace motor :-)
http://m.grainger.com/mobile/details/?R=4MB23
Matches frame,amps, size, shaft. Needs a psc 5uf cap.
Since my current system uses a dual motor run cap (35/3/440), can I substitute this (35/5/440)
http://m.grainger.com/mobile/details/?R=2MEJ5
For the current one
http://www.northamericahvac.com/serv...Comfort/Detail
beenthere 08-26-2012 08:06 PM
Ya, 35/5/440 will work fine.
purduephotog 08-27-2012 07:47 PM
Replaced fan and cap. Old fan, once off, showed a couple of rough spots when turned and wouldn't spin freely. Note to self- buy a clamp meter.
New fan and cap running now, seems OK.
Is there a special term for a reduction sleeve I can slip over the new cap to fit the old hole size?
Thanks all. Only an hour to install and about 200 mosquito bites.
beenthere 08-28-2012 04:14 AM
I just use plumbers strap when the old clamp is bigger then the new cap needs.
