Compressor Fan Never Turns Off And Never Blows Cold - Trane XE 1000 - HVAC - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 04:53 PM   #1
Compressor fan never turns off and never blows cold - Trane XE 1000
Guys,
I have a 12 year old Trane XE 1000.
Came back from a road trip and found it wasn't blowing cold air.
Went outside and discovered the compressor fan was NOT turning.
I reset the breakers & checked cap (it was good) and put everything back together.
Then it came on just fine, but I noticed one of the heavy guage power cables was jumping around, so I powered it all off.
Found the cable was shorting to the chassis. I fixed this and powered everything up again.
Now the compressor fan never turns off? It's constantly running!
And none of the pipes are cold and no cold air is coming through the vents.
Any suggestions on how to t/s the problem?
The red cable at the bottom of this pic is the one that was shorting out.
The circled spring button does not plunge down when I turn on the breaker power. I *think* that's what it's supposed to do?
But the fan instantly starts running.
CZ DIY is offline   Reply With Quote
Old 04-02-2012, 05:23 PM   #2
An old Tradesmen
Rewards Points: 6,152
Could be a blown capacitor. The contactor will remain pulled in as long as the indoor unit is sending 24 volts to it.
Old 04-02-2012, 05:55 PM   #3
Cap has all the correct values so it seems ok. Thanks though.
Old 04-02-2012, 06:11 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
Motor winding may be shorted to ground and is causing the motor to spin. Does it spin at full speed even with the contactor not pulled in? As far as the rest not working the contactor would need to pull in to allow power to flow through to the compressor and fan motor. ( that is likely a separate issue from your fan constantly spinning)
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-02-2012, 06:13 PM   #5
Rewards Points: 614
are you sure thats where the red wire camr off....looks suspicious
carmon is offline   Reply With Quote
Old 04-02-2012, 06:44 PM   #6
I never moved the red wire and it worked before
How does the "pull in" work? I will be getting a new contractor in the mail tomorrow.
Sent from my SAMSUNG-SGH-I727 using DIY Chatroom
Old 04-02-2012, 06:46 PM   #7
The fan moves at the same speed regardless of whether I manually press the button or not.
Old 04-04-2012, 08:18 PM   #8
So I replaced the control contractor and now the compressor fan is working properly.
But still not blowing cold.
Brought an HVAC tech out.
Sonofa...
The compressor wouldn't turn on, so he can't charge it with freon.
Says he can either replace the outside unit with a used one he just removed today from my neighbor, for $450 OTD.
But he thinks that it may be a bad evaporator coil leak.
And I need to replace the entire system. So many thousands of dollars that I don't have right now.
_____________
Old 04-05-2012, 05:02 AM   #9
An old Tradesmen
Did he say why the compressor won't run?
Old 04-05-2012, 12:02 PM   #10
REP
I just happen to have one reeks of red flags.
Now it isn true that you need the compressor running in order to tell if the charge is correct but even with it off you can tell if there is a charge in the unit.
Did he put the gauges on at all?.Why does he think there is a leak at all?
If he hadn't been there yet I would have suggested you try replacing the capsitor because that could keep the compressor from starting and it could have been taken out with a short.
At the very least get another opinion .I have no way of knowing but this one sounds fishy.
REP is offline   Reply With Quote
