Compressor Fan Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 05:48 PM   #1
Compressor Fan motor
Hello first time posting. I have a Carrier A/C unit and yesterday the compressor fan motor did not come on when it was supposed to. I went and checked it and it sounded like it was jammed or something "motor trying to move but nothing would happen" I moved the fan with a stick and it the fan began working on its own. As the day went on I realized that the fan would continue to not start on its own but work if I got it going. I took the fan of and it looks like the bearings are fine. Would this be typical of a bad motor or something else. You help is greatly appreciated.
TiAgM3 is offline   Reply With Quote
Old 04-26-2009, 06:13 PM   #2
HVAC / Plumbing
check the start capacitor
kenmac is offline   Reply With Quote
Old 04-26-2009, 06:35 PM   #3
An old Tradesmen
Rewards Points: 6,824
Ain't got a start capacitor.
Its a run capacitor.
Trivial, until you use a start cap and burn up the motor. Or worse.
Old 04-26-2009, 06:41 PM   #4
How do you check the capacitor? From the reading I have been doing it is a dual purpose capacitor. The motor is a HC39GE237A with 3 wires (brown/yellow/black) coming into it.
Old 04-26-2009, 07:15 PM   #5
HVAC / Plumbing
mis worded.. My mistake.. Yes it's split part for comp & part for motor.. There are cap. testers . You can use v m. to know if it's gone.. Some will look bloated. Like they are about to expload
Old 04-26-2009, 08:08 PM   #6
You'll need a DVM, a 9v battery, some clip leads
http://www.positiveoffset.com/Parts/BanGatorLeads.jpg
and a one megohm resistor from Radio Shack.
Can you post a photo of the markings on the cap? Look for "uF".
dayton fan motor Turk Electrical 1 02-27-2009 05:38 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Air Compressor Motor Hums, Trips Breaker pointertopica HVAC 10 12-02-2008 10:20 PM
Goodman motor availability NomadTrash HVAC 5 11-08-2008 11:01 AM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
