Compressor Concerns - HVAC - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 04:19 PM   #1
Compressor concerns
can you replace a compressor that is in a matching 410a system 13seer, recover old refridgerant, vacume lines for 1 hour, and then charge with R-22?. i had my compressor replaced and i know it was 410 and the the tech who replaced it did told me it was 22. everything is ok, so far i guess. i dont know a little bit but nothing in this nature.
any ideas??
airtech77 is offline   Reply With Quote
Old 08-04-2011, 04:36 PM   #2
Rewards Points: 338
yeah i'm pretty sure without a flush and cleaning of the lines you can't do that. the oil used by the two refrigerants are different and do not mix and any residual that was left over in the lines will be mixed in with the R22 oil. not sure how soon or when you will see problems, but i imagine it will wear out your compressor a lot faster.
NitroNate is offline   Reply With Quote
Old 08-04-2011, 04:39 PM   #3
ok. so an evac of the system,flush,new vacume and filter dryer and fresh 410 will do the trick?
Old 08-04-2011, 04:55 PM   #4
JJboy's Avatar
Here are the products you need to use to properly to flush your system
http://www.rectorseal.com/index.php?...1&product_id=2
http://www.rectorseal.com/index.php?...roduct_id=2107
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-04-2011, 05:05 PM   #5
Rewards Points: 338
looks like it is ok to mix a small amount of POE with mineral oil in an R22 system and it may actually help in oil return. the other way around will not work because mineral oil is not compatible with R410A or any HFC, but i even visited copeland's website and they say that POE and MO can be mixed in CFC or HCFC applications.
Old 08-04-2011, 05:09 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
What the heck are we talking about here. R22 and 410 have COMPLETELY different operating pressures and are not interchangeable nor are the compressors. Check the rating plate on your outdoor unit to see if it is a 410 unit.
Old 08-04-2011, 05:15 PM   #7
so u can completly charge a 410a system with 22 b/c the design pressures are different, 22's are lower than 410a's
Old 08-04-2011, 05:25 PM   #8
If it's a 410 system tell the guy to come back and do it right, for free of course. Somebody mess up big time on that one.
Old 08-04-2011, 05:31 PM   #9
HVAC Tech/Owner
Rewards Points: 604
I would get the wrong refrigerant out of that system ASAP, they are not compatible. I wouldn't worry about any flushing because there has been no cross contamination of oil............unless an r22 compressor was put in, instead of r410
Technow is offline   Reply With Quote
Old 08-04-2011, 05:58 PM   #10
I think that's what happened technow. System was 410a and somebody put a 22 compressor in and charged it with 22. How would you like to be the next guy to work on that one?
Old 08-04-2011, 06:38 PM   #11
HVAC Tech/Owner
Rewards Points: 604
Actually....I would rather be the next guy than the one that did it
