Compressor Burnout Change All Filters? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-09-2011, 11:16 PM   #1
compressor burnout change all filters?
I have seen a few pro's leaving in the old compressor suction line filter even after putting in a new compressor after the old compressor failed via an burnout with acid....When I questioned them they say it is not needed...to put in a new suction filter.
Would any of the PROs here leave in the dity suction line filter?
Copeland states in an AE thet do approve of addatives to the compressor oil what does this mean acid away is s no no?
tomcat862 is offline   Reply With Quote
Old 10-09-2011, 11:27 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
If it were a burn out then the old driers, both the high and low side if they were there, should have been replaced.
The low side drier is recommended to be removed after only a few days.
Acid Away is good but a solid nitrogen charge/cleaning followed by a triple evacuation and new filters is always best.
Doc Holliday is offline   Reply With Quote
Old 10-10-2011, 12:17 AM   #3
JJboy's Avatar
This is the difference between PRO and pro...
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-10-2011, 04:24 AM   #4
An old Tradesmen
Rewards Points: 7,404
No reason to leave an old filter in. Usually is don e cause they are too lazy to replace it, or don't have another one with them.
Old 10-10-2011, 06:00 AM   #5
Rewards Points: 1,216
Always change.
COLDIRON is offline   Reply With Quote
Change Orders ELVISQUEEN General DIY Discussions 6 09-16-2011 11:53 PM
Cut to Fit fiberglass filters GEAF HVAC 1 03-24-2011 12:49 PM
Al. mesh filters lottaair HVAC 1 09-13-2010 05:34 PM
Central air conditioner filters Jax newbie HVAC 4 11-10-2008 09:24 AM
My HVAC repairman recommends cheap filters? scarl HVAC 9 08-16-2008 06:09 PM
