Compressor Bad On 9 Year Old Carrier?? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 10:58 AM   #1
Compressor bad on 9 year old Carrier??
My AC was not cooling the house and periodically making a squealing sound. I have been told my compressor is bad on my 9 yr. old carrier AC unit. Got a quote to replace the compressor and a quote to replace the unit. There's only a few hundred dollars difference between the two. Does this sound correct? Is it possible to replace the compressor on my own? Any thoughts or comments would be appreciated.
GravelGuy is offline   Reply With Quote
Old 07-12-2012, 11:58 AM   #2
Rewards Points: 242
only if you have a recovery machine,recovery tank,vacume pump. micron gage, scale, freon, torch kit, and your EPA certification. why the price is close is the labor to replace a compressor is longer than replaceing the outdoor unit. if you replace the compressor, remember the fan motor, controls are nine yrs old too.
hvac instructor is offline   Reply With Quote
Old 07-12-2012, 12:16 PM   #3
Thanks, I was leaning towards replacing the entire unit as you suggested.
Old 07-12-2012, 11:24 PM   #4
Rewards Points: 616
it should be way less for compressor change only..... not a smart idea on a 9 year old unit in my opinion............
carmon is offline   Reply With Quote
Old 07-13-2012, 12:46 AM   #5
might be the case in the great white north but nation wide in the US the diff between a cmp and condenser change out IS so close that a new unit is more feasible,
hvac5646 is offline   Reply With Quote
Old 07-13-2012, 07:17 AM   #6
biggles's Avatar
if it is a mechanical failure it is an easy change out and should be cheaper then a new condenser change out.if it is a burn out (which yours isn't)thats closer to a change out dryers,clean up of system new freon.what freon is the exsisting system...might have to go with a R-410A update then there in on the air handler changing stuff.staying with the original freon and just a compressor change should be considered.
Carrier Gas pack Model number peakslayer HVAC 0 01-10-2011 12:02 PM
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 12:27 PM
Carrier 58MXA furnace question Jen G HVAC 2 11-24-2010 04:33 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Carrier Infinity thermostats integrate with control4 2.0 Proteco HVAC 0 07-09-2010 06:33 PM
