Compressor/Air Handler Mismatch - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 09:24 AM   #1
Compressor/Air Handler mismatch
I have a 3 ton compressor and a 2 1/2 ton air handler. Probably been that way for 18 years. Is this a problem?
bkrulak is offline   Reply With Quote
Old 04-17-2013, 10:57 AM   #2
Rewards Points: 446
I would think the 18 years of service would be a good case for it not being a big problem.
The only thing would be is if the 2 1/2 ton air handler is a dedicated one size only unit. The effect would be a loss of efficiency..... would cost you more to operate verses a properly sized pair. As long as the system was setup to deal with the potential imbalance, no harm, just a foul so to speak.
"Some" air handlers were and still are designed and built to be able to be a match for more than one size condenser. Sometimes, but not always, this is identified in the model number.
old_squid is offline   Reply With Quote
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 31 06-02-2016 05:02 PM
Do I really need the air handler filter? Flt_Simulation HVAC 2 09-17-2012 10:38 AM
Return Vents and Air Handler Question hifiman HVAC 7 04-27-2012 06:44 AM
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 12:55 PM
Full drip pan caused AC unit to cut off; now compressor/air handler will not work bizzow HVAC 1 08-14-2011 04:52 PM
