Compresser Unit Running Ok, Try's To Restart - HVAC - DIY Chatroom Home Improvement Forum
Old 09-25-2009, 01:45 PM   #1
compresser unit running ok, try's to restart
outside Air conditioner compresser unit running ok, but keeps trying to restart, it buzz's for about 2 sec. once every mim. to 5 mim some times then is ok for an hour or so then trys to restart again ?
please help
Pat33019 is offline   Reply With Quote
Old 09-25-2009, 05:09 PM   #2
The first things I'd look at would be contactor,
low voltage supply and connections.
hennyh is offline   Reply With Quote
Old 09-25-2009, 11:44 PM   #3
The compressor's overload is kicking it off after trying to start. They make a jump start capacitor you can try as a quick fix depending on hold old your unit is. I don't really like using them on every unit just as a solution to try and get a little more life out of a compressor.
Daniel048225 is offline   Reply With Quote
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
AC Unit Running All The Time Data Captured... GeorgeCJ HVAC 4 07-24-2008 08:36 PM
