Complicated HVAC / Thermostat Question - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 09:13 AM   #1
Hello,
I have been trying to research thermostats for a few months now and have been unable to find the information I need to select something that fits my needs.
My needs:
I have a two zone (upstairs / downstairs) forced hot water baseboard heating system. Right now I have a thermostat upstars and one downstairs. I want a 7 day programmable thermostat that can control both zones from downstairs place. I assume I would need to replace the upstairs thermostat with a temperature sensor, because I actually want the zones to stay independent.
I have looked at Honeywell controllers mostly, and find it very hard to determine if they can in fact control multiple zones with a remote temperature sensor.
I am open to anything. thoughts? suggestions?
tlynch99 is offline   Reply With Quote
Old 10-25-2010, 10:00 AM   #2
Rewards Points: 292
Originally Posted by tlynch99 View Post
Hello,
My needs:
Not a PRO, but I believe that a (some, maybe all?) remote sensor is used by a stat to 'average' temperatures in 2 zones, not control each separately.
veesubotee is offline   Reply With Quote
Old 10-25-2010, 10:16 AM   #3
Thanks for the quick reply... I think what you said makes sense in most applications. Remote sensors are used to solve the "well I want to take the room temp here, but don't want to actually place the controller here" problems. I really don't care if I have to have two thermostats or two remote sensors, I really just want to be able to control both of them, from a decent looking (interface wise) device.
Old 10-25-2010, 04:32 PM   #4
An old Tradesmen
Rewards Points: 7,362
Honeywell thermostats can use a remote sensor. So if you get 2 TH8320 thermostats. One can do the down stairs, and the other with a remote sensor, can control the upstairs.
Old 10-25-2010, 04:51 PM   #5
So in that configuration I would still have two actual thermostat control units? So two TH8320's? Is there then something that would control both of those? I am really looking for a centralized display for both zones?
Old 10-25-2010, 05:06 PM   #6
An old Tradesmen
If you want a centralized display. You need to move up the expensive commercial controls.
Is the upstairs an apartment?
Old 10-25-2010, 05:08 PM   #7
No the upstairs is not an apartment, but I guess what I want would make a lot of sense in that application.
Ok so lets say I need a commercial control... what are we looking at... what commercial controls do what I want?
Old 10-25-2010, 05:15 PM   #8
An old Tradesmen
A bacnet or lon systems is a bit prohibitive.
But here is a link to Ecobee. You can use 2 of their stats, and control both from your computer, or anywhere in the world you have online access.
Old 10-28-2010, 03:57 PM   #9
Thanks for the responses. The ecobee seems like it's closer to what I want but I would still need 2 thermostats.
Is what I am looking really non-existent?
Old 10-28-2010, 06:56 PM   #10
An old Tradesmen
Is not something used in the residential market.
Old 10-28-2010, 07:59 PM   #11
Ok, what commercial options are there. I don't mind paying, I just want to understand what is available.
Old 10-28-2010, 08:12 PM   #12
An old Tradesmen
Do a search on BAS. Building Automation Systems.
You'll have remote sensors. And a main unit. that interfaces with your PC. The sky is the limit then.
Price, starting around 2 grand.
HVAC Register Question bphyatt HVAC 6 12-17-2009 08:57 AM
Quick HVAC / sump pump wiring question MattOverMinder Electrical 4 01-23-2009 07:42 AM
HVAC return vent location question fatboy HVAC 1 03-10-2008 08:56 PM
Thermostat question MsApril HVAC 1 02-09-2008 06:00 PM
