Old 11-26-2007, 07:54 PM   #1
Compatible thermostat for Lennox
Hi there. I'm shopping for a programmable thermostat for my Lennox Elite cb29m. However, it was in the house when we moved in; I dunno if it's a multi-stage, etc. -All I know is we are not using gas and have no ceiling coil heat.
Anyone have any ideas how I can indentify compatible stats, or even suggest a reasonably priced unit?
Thanks in advance,
R Davis
robdville is offline   Reply With Quote
Old 11-26-2007, 08:32 PM   #2
Thoroughbred Mopar Man
Hi robdville
You have a fan coil unit and should have a heat pump. If you want a good reliable workhorse thermostat, I would reccomend a White Rodgers 1F89-311 for a non programable or a 1F86-261 for a programmable. It will have the wiring configuration in the box.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 11-26-2007, 09:40 PM   #3
Thank you so much for the quick reply; this is exactly what I needed to know!
I've googled your suggestions, but am having little luck. I've also checked the white-rodgers site, but no record of the 261 thermo. Do you happen to know if this will work?
http://thermostats.idtenergystore.co...product=101561
Thanks again!
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 10:58 PM
NOMA Thermostat brobinson68 HVAC 5 01-17-2007 03:36 PM
Lux 722E Thermostat mgkicker HVAC 3 10-27-2006 02:40 PM
