Compatible A/C Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 11:51 AM   #1
Rewards Points: 41
Compatible A/C Unit
I am buying a home and unfortunately the condenser was stolen and some copper lines. Luckily the inspector took pictures and I was able to get the model number.
GSC130481
I was wondering if it is as simple as ordering a new version of this? Mine was actually called an Everrest but it was just the rebranded Goodman. It was produced in 2007....I was just wondering if there would be incompatibilities or if newer units use different coolant.
I found these 3 units:
http://www.theacoutlet.com/GSC130481.htm
http://www.theacoutlet.com/GSC130483.htm
Both seem to be the same except for the 2 phase....any way to tell which would be best or work?
Thanks,
Steven Penny
01grander is offline   Reply With Quote
Old 06-25-2012, 12:38 PM   #2
JJboy's Avatar
Get the model and serial number of furnace for better cross reference.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-25-2012, 06:19 PM   #3
An old Tradesmen
Rewards Points: 6,544
A compatible Goodman dry R22 unit is still made today.
The Following User Says Thank You to beenthere For This Useful Post:
plummen (06-25-2012)
Old 06-26-2012, 12:12 PM   #4
Rewards Points: 41
Good to know. How do you tell the differnce between a gas furnace and a air handler? The serial number isn't visible and I cant tell which one it is. I don't think I have a furnace anywhere else but I am not sure.
Sorry for sounding incredibly stupid but I've never had to deal with a HVAC system before so I don't know by looking at it.
Old 06-26-2012, 12:32 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
A gas furnace would have a metal exhaust pipe running from it and out through the roof, like a long vehicle muffler pipe.
Air handlers utilze electric heat strips, no exhaust.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-26-2012, 03:39 PM   #6
An old Tradesmen
or a gas furnace could have a PVC vent pipe going out the roof, or the wall.
Old 06-26-2012, 04:23 PM   #7
bubbler's Avatar
Rewards Points: 256
Nobody mentioned it yet, but obviously you'd only get the 3-phase if you had 3-phase power available. Since this is residence, you almost certainly don't have it.
...another thing is to consider what your end goal here is. Are you planning to DIY this install, or just trying to figure out what is possible and figure some materials costs? DIY seems like a stretch. This seems like a case where getting multiple bids from local contractors would make the most sense.
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 05:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 04:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 08:50 PM
Can I upgrade the compressor in my RV roof AC unit? eoptrab HVAC 10 09-02-2010 05:43 PM
