Old 10-28-2009, 08:29 PM   #1
Default Compatability question (cooling unit to heat pump)
I currently have a goodman 2-ton cooling unit (CKL24-1L) that is a 2ton unit and want to switch to a goodman 13 seer 2-ton heat pump condenser (GSH130241). I have a goodman ARUF024-00A-1A air exchanger unit that the cooling unit goes through. Are these units compatible with one another? Do i need to get a thermal exchange valve to accomodate this change? Also, i need to get heat strips put in.
So in summary: are these three units all compatible with one another?
http://cgi.ebay.com/Goodman-10-Kilow...item2553ced870
and
http://www.amazon.com/Goodman-GSH130.../dp/B001CB8Q3Y
and
http://villa-villekulla.com/villa/cu...er%20Specs.pdf
Thanks in advance!
Common is offline   Reply With Quote
Old 10-28-2009, 08:56 PM   #2
Master Plumber/Mechanical
Yes they can be matched.
If you had opened the last attachment and crossed numbers your self you would have seen this
On a side note. IMHO Goodman is crap
Are you going to try and install this yourself or do you have help?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-28-2009, 09:44 PM   #3
Home Air Direct's Avatar
Beware, The Goodman AC unit you currently have is probably a 10 SEER. The Air Handler was produced with the same ARUF024 number as a 10 SEER designed unit, and then when the standards changed in 06, the ARUF024 number is still used, but the coil that it contains was altered to be 13 SEER compatible. I would have the serial number ran and have Goodman confirm.
I am skeptical that you have a match.
Good Luck
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
More On This Topic
This is just actually the shell of a fork, because I want to show you guys what the difference is. So these are called lowers, they're usually cast out of magnesium, they can either have a through axle or you know, a normal quick release axle like this... Read More »
Learn the meaning of the Gilt Leaf Seer and how to use it when you play 'Magic: the Gathering' in this free video. Read More »
For someone who barbecues often or merely enjoys the smoked taste of meat, a built-in smoker is a dream come true. As an addition to an outdoor kitchen, the built-in smoker doesn't take up as much room as it would if it were not built-in. But the final... Read More »
Do not let a fly-by-night tour operator make off with your money and your vacation dreams. A little homework will go a long way toward giving you peace of mind, especially when dealing with an unfamiliar tour company. Follow the steps below to ensure... Read More »
Hi! I’m Roy Stringfellow for expertvillage.com. We’ve build our coil pot up to about this size and the next thing that we’re going to do is pull it out of our form, which is kind of tricky sometimes. You’ll notice this is kind of... Read More »
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 02:27 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 04:11 PM
please suggest me a heat pump system. caseym HVAC 7 10-10-2007 08:41 PM
Getting a House..heatpump or no? DavidsCPU HVAC 9 11-27-2006 08:08 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 11:10 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
