-   -   Compatability question (cooling unit to heat pump) (http://www.diychatroom.com/f17/compatability-question-cooling-unit-heat-pump-56162/)
Common 10-28-2009 06:29 PM
I currently have a goodman 2-ton cooling unit (CKL24-1L) that is a 2ton unit and want to switch to a goodman 13 seer 2-ton heat pump condenser (GSH130241). I have a goodman ARUF024-00A-1A air exchanger unit that the cooling unit goes through. Are these units compatible with one another? Do i need to get a thermal exchange valve to accomodate this change? Also, i need to get heat strips put in.
So in summary: are these three units all compatible with one another?
http://cgi.ebay.com/Goodman-10-Kilow...item2553ced870
and
http://www.amazon.com/Goodman-GSH130.../dp/B001CB8Q3Y
and
http://villa-villekulla.com/villa/cu...er%20Specs.pdf
Thanks in advance!
Plumber101 10-28-2009 06:56 PM
Yes they can be matched.
If you had opened the last attachment and crossed numbers your self you would have seen this
On a side note. IMHO Goodman is crap
Are you going to try and install this yourself or do you have help?
Home Air Direct 10-28-2009 07:44 PM
Beware, The Goodman AC unit you currently have is probably a 10 SEER. The Air Handler was produced with the same ARUF024 number as a 10 SEER designed unit, and then when the standards changed in 06, the ARUF024 number is still used, but the coil that it contains was altered to be 13 SEER compatible. I would have the serial number ran and have Goodman confirm.
I am skeptical that you have a match.
Good Luck
