Common Duct Sizes? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 01:12 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
Common Duct Sizes?
I realize that to have an accurate size, one needs to do the numbers through the manual J. I can't do that right now....
So....what are the common sizes of duct you would typically run to a bedroom that is around 100 sq ft....?
And to a family room that is around 250 sq ft?
Based on input you gave me in a previous thread...I'll be doing metal ducts...not flexible....
ddawg16 is online now   Reply With Quote
Old 02-16-2013, 01:32 PM   #2
An old Tradesmen
Rewards Points: 6,846
A 6 or 7".
3-6", or 2-6" and 1-7", or 1-6" and 2-7", or 2-7" and 1-8", or 3-7".
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (02-16-2013)
Old 02-16-2013, 03:21 PM   #3
JOATMON
ddawg16's Avatar
Originally Posted by beenthere View Post
A 6 or 7".
Translate? I'm a software kind of guy....."pop" and "move" make more sense to me....
Old 02-16-2013, 03:30 PM   #4
MarginallyQualified
Rewards Points: 2,464
Look through a catalog...
http://www.standexadp.com/products.php
Old 02-16-2013, 06:05 PM   #5
An old Tradesmen
You said common. All of those sizes are common depending on room set up/construction.
Since no real description of the room construction, I gave common sizes for multiple types of construction and room orientations.
Old 02-16-2013, 09:07 PM   #6
Rewards Points: 582
bt gave common sizes of duct you would find in a home ..translate to what... what size and layout do you have... how much sq footage do you have ..what is you load...what is your insulation value...you ask for common sizes..thats what you got...ben sr
Old 02-16-2013, 11:24 PM   #7
JOATMON
ddawg16's Avatar
Room #1...100 sq ft.....R13 in the walls.....mild climate
Room #2.....240 sq ft....R19 in the walls.....mild climate
Upstairs....not worried about....I have a gas fireplace up there.
duct sizes for each of my rooms slash5bmw HVAC 3 05-16-2012 03:42 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Duct work in garage. flashme18 HVAC 1 11-08-2009 06:29 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 09:38 AM
duct sizing Stu HVAC 2 12-22-2006 05:36 PM
