Commercial Freezer Grounding/Neutral Help - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 07:18 PM   #31
Ok I am going to recheck everything and try a different and new 20 AMP breaker. Maybe the two breakers I had were weak or compromised.
LFYN is offline   Reply With Quote
Old 02-06-2013, 07:19 PM   #32
An old Tradesmen
Rewards Points: 6,470
Is the 20 amp breaker an HACR breaker?
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (02-06-2013)
Old 02-06-2013, 07:35 PM   #33
I'm not sure will check
Old 02-06-2013, 08:00 PM   #34
Yes it is
Old 02-06-2013, 08:26 PM   #35
An old Tradesmen
OK. A 20 amp should be more then enough for the load then.
Old 02-06-2013, 09:58 PM   #36
Rewards Points: 484
That freezer was designed to be plugged into a 20 amp circuit and should run without tripping the breaker. If the breaker is not suspect, than I would say there is an internal problem with the freezer itself and installing a larger breaker is only a bandaid fix.
sammy37 is offline   Reply With Quote
Old 02-07-2013, 06:48 AM   #37
Rewards Points: 1,216
Did you hand over hand the circuit that the unit is tied to?
In other words are you absolutely sure there's nothing else wired in the same circuit the unit is on?
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 02-07-2013, 07:26 AM   #38
Yes 100% dedicated. The line didn't exist until the freezer was acquired. The line goes directly from breaker to outlet. Approximately 20-25 ft. One thing I did tho was replace the metal outlet box with plastic just to be positive and to eliminate any potential errors or defects. That was at the same time I installed the 25 amp. Now that it hasn't tripped since, I'm going to try the 20 amp again to see what happens
Old 02-07-2013, 08:19 AM   #39
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
Did you check the voltage each time you went there. should not be lower than 110 volts. Low volts = high amp draw. Check the wiring diagram or evap coil, some units have a dts/ defrost termination switch which should prevent the evap overheating from defrost. defrost conditions change with the season and humidity and load etc so you ideally should not have to monkey with the time clock and the switch will shut the elements off when the coil gets to the setpoint. it may be stuck closed. may not look as elaborate as this one, may be a simple round device 1" in diameter clamped to the suction line at the evap end with 2 wires coming out. pretty dammn good article also.
http://blog.uscooler.com/defrost-ter...delay-control/
Refrig. not enough cooling top (freezer) or bottom bottom justplumducky Appliances 6 11-19-2012 11:19 AM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 11:32 PM
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 09:32 AM
Freezer odors - coming from blower/fan Richo Appliances 3 05-27-2009 06:26 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
