Comfortmaker Softsound 10+ Compressor - HVAC - DIY Chatroom Home Improvement Forum
Old 05-06-2009, 02:57 PM   #1
I have a comfortmaker softsound 1000+ heat pump (model chp048akc3). Last night, the condensor started making a loud whinig sound. When I checked it out, the fan was not spinning, but looked like it wanted to. I gave it a nudge, and it started spinning again, then slowed down and stopped. Hard. Nudged it, and back to spinning. I thought it might be the bearings in the motor were shot. But with the unit off, the motor spins freely, no binding that I can see. Any ideas what may be wrong with this motor? Could it be the capacitor? Do i need a new motor? Thanks for any help.
etcwhitlock is offline   Reply With Quote
Old 05-06-2009, 05:37 PM   #2
One other question. I found a replacement fan at Grainger. It is not OEM, but seems dang close. Same voltage, frame, bolts, size, everything. Only difference is RPM. According to the specs for my unit, the original fan runs at 840 RPM. This new motor runs at 1075 RPM. Is this going to work? I would think a little more RPM shouldn't hurt. It it wasn't enough, I caould understand. Any ideas?
Old 05-06-2009, 08:31 PM   #3
HVAC / Plumbing
Check the capacitor.. If it's the motor. It would be wise to replace it with the same RPM & install new fan
kenmac is offline   Reply With Quote
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Compressor died, can it be replaced DIY? Firecracker HVAC 11 09-01-2008 08:41 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
Comfortmaker A/C compressor not running catamaran HVAC 5 09-02-2007 03:20 PM
