Comfortmaker RPJ2 Won't Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2006, 03:08 AM   #1
Comfortmaker RPJ2 won't ignite
I am having a problem with my Comfortmaker RPJ2. This all started this evening when we came home and the thermostat said it was 55F when the thermostat was set to 72F. I took a look at the furnace and the red light indicator was blinking 1 flash - system lockout due to retry. I tried to reboot following the instructions on the front panel and after all the fans, ticks and such, no flame in the furnace and them the red light indicator was blinking 1 flash again. I wasn't getting a flame in the furnace at all so, I thought it might be the igniter. Tried sanding it down to remove any grit and residue. Still nothing. Is the ignitor rod sticking into the far left gas thing (whatever it's called) supposed to turn orange or some color to indicate that it is working. Mine didn't when I was trying to get it to work. I was able to confirm that power was being sent through the wire. Could it be the igniter is bad?
PLEASE HELP!!!
Ty
tyear8299 is offline   Reply With Quote
Old 03-05-2006, 05:06 PM   #2
sub-contractor
I hope that you sanded the flame sense rod. because if you snded the ignitor then it's broken now.
The flame sense rod is a little rod that sits directly in front of the burner with one wire running to it. and the ignitor has a black and a white wire running to it.
The problem has nothing to do with the flame sense rod, since the burners aren't even at the stage of igniting. Is it a spark ignition or an ignitor?
Aceinstaller is offline   Reply With Quote
Old 03-27-2015, 05:18 PM   #3
Rewards Points: 2
RPJ2 Furnace Won't Light
I have a similar RPJ 2 furnace. My furnace is staying in the purge mode and will not ignite. Sounds like a bad controller to me. Anyone have any ideas?
rellek is offline   Reply With Quote
Old 03-27-2015, 06:20 PM   #4
Rewards Points: 582
PLEASE HELP!!!
Ty
if you are sure that you have power to ignitor..and it won't glow...bad ignitor...
Old 03-27-2015, 08:20 PM   #5
Rewards Points: 3,518
This thread is 9 years old, it would have been better to start a new one.
But for your issue, many are quick to blame the board but they are rarely the issue. Does the unit have adiquate gas supply? What's the gas pressure? Is the gas valve being powered? If not, then what's causing a lack of voltage? If yes, then is the valve opening? If so, is the ignitor coming on? Is a safety tripped?
roughneck is online now   Reply With Quote
Comfortmaker furnace problem dragon2125@hotmail.com HVAC 2 12-07-2008 02:12 PM
Comfortmaker RPJ2 rusty55125 HVAC 4 04-03-2007 10:27 PM
gmp100-3 furnance won't try to ignite davewolf HVAC 5 11-21-2006 03:13 AM
Comfortmaker GNL won't start Hollandpiper HVAC 2 10-10-2006 03:37 PM
Comfortmaker RPJ2 rusty55125 HVAC 5 01-02-2006 04:26 PM
