Comfortmaker RPJ-II - Won't Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 06:46 PM   #1
Cabin Guy
Send a message via ICQ to leedef Send a message via Yahoo to leedef Send a message via Skype™ to leedef
Comfortmaker RPJ-II - won't stay lit
I seem to have 2 problems happening at once.
When heat is called for the Evac fan runs for about 30 seconds as it should. Then the igniter glows for about 5 seconds, then the valve clicks and the far right burner (#1) lights... the flame migrates to burner #2 and it lights... the flame migrates to burner #3 and it lights... then the flame migrates to burner #4... and IT DOESN'T LIGHT... and the unit shuts down immediately.
However, if I insert a lit fireplace lighter at the opening of burner #4 just after #3 lights it ignites and burns fine... only to have everything shut down after 20 seconds or so.
Please see attachment.
Is it possible that I have something clogging the opening (spider web or such) where the flame is supposed to "walk" across from burner #3 to #4? If so, how do I clean it?
In addition, because the system shuts down even though I get all 4 burners going, might I also have a bad Flame Sensor?
leedef is offline   Reply With Quote
Old 10-22-2008, 08:58 PM   #2
30 year tech
hvac122's Avatar
Sounds like you just need a good cleaning. Clean out the burner crossovers and clean the flame sensor with scotchbrite.
hvac122 is offline   Reply With Quote
Old 10-22-2008, 10:25 PM   #3
HvacWiz's Avatar
Rewards Points: 252
You might want to check the gas pressure also.
HvacWiz is offline   Reply With Quote
Old 10-22-2008, 10:35 PM   #4
Originally Posted by HvacWiz View Post
You also might want to check the gas pressure also.
word!
hvaclover is offline   Reply With Quote
Old 10-23-2008, 11:03 AM   #5
Cabin Guy
Any special technique for cleaning the crossovers?
Old 10-23-2008, 12:44 PM   #6
A brass or stell brush is recommended. However you must be carefull not to open the cross over groove. That is do not try to expand the opening to get at dirt and corrision.
It is very possible that the ceross over is corroded beyond repair.
If you have scrubbed the cross over as throughly as possible and it still doe not work then you will have to buy a new burner.
Old 10-29-2008, 05:20 PM   #7
I use a hacksaw blade on the crossovers and if I bend too far open just tap back to size, works great, check orifice holes also.
Simpleman
simpleman1962 is offline   Reply With Quote
Old 10-29-2008, 07:42 PM   #8
Simpleman
LOL...you like to live dangerously. I tried to do something similar and when my ICP dist found out he damn near dumped my account.
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 06:41 PM
'93 Comfortmaker RPJ propane furnace lifespan? Dawsonhope HVAC 5 11-21-2008 05:47 AM
Lights stay on wsixsmith Electrical 19 08-05-2008 06:43 PM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 05:16 PM
