Comfortmaker Low Airflow - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 06:42 AM   #1
I have a Comfortmaker NTG3075FBG1 forced air system. Before yesterday, I had no issues with heat or A/C. Now, when A/C kicks on, everything sounds "normal" (short delay, outside compressor comes on, air handler blower starts). However, at the floor registers I can feel almost no air coming out. A little research tells me its a 1/3 HP 4 speed motor (HQ1012514EM). I was at first thinking I lost the "high" speed. The problem is that I do hear the motor running, and I feel air flow in the plenum. If a "speed" fails, does it default to a lower speed? Any ideas on this before I start taking things apart?
OscarNJ is offline   Reply With Quote
Old 06-22-2009, 12:22 PM   #2
You may have a dirty air filter or dirty evaporator coil.
http://www.diychatroom.com/f17/
Check this thread out if a new filter doesn't cure your trouble.
SKIP4661 is offline   Reply With Quote
Old 06-22-2009, 05:05 PM   #3
Agreed
I also had some icing. Between the two they blocked the flow aout 90%. A little degreaser and I'm good as new.
Old 06-22-2009, 07:06 PM   #4
sktn77a's Avatar
Rewards Points: 392
Icing may have been due to low refrigerant charge, in which case, it will just happen again. Did you determine the cause?
sktn77a is offline   Reply With Quote
Is my furnace suitable to my home size? (poor airflow) knottshawk HVAC 15 06-01-2009 09:17 AM
Poor airflow to living room mainstreetprod HVAC 8 01-16-2009 08:13 PM
'93 Comfortmaker RPJ propane furnace lifespan? Dawsonhope HVAC 5 11-21-2008 05:47 AM
Comfortmaker Furnace tmcdougall HVAC 2 10-08-2008 07:24 PM
comfortmaker flame sensor big ron Appliances 1 11-02-2007 09:20 AM
