Comfortmaker Ignition Issues - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 12-17-2009, 09:26 PM   #46
An old Tradesmen
Rewards Points: 6,160
Personal attacks are not generally tolerated.
When a person changes the description of the problem/symptoms. it does make most people curious though.
Post your questions. And if you give a reasonably accurate description(include removing pilots sometime ago helps). Generally you'll get answers that help.
Old 12-17-2009, 09:31 PM   #47
Thanks,
I believe that it was an afterthought because of the time between issues.
Srsci is offline   Reply With Quote
Old 12-18-2009, 12:52 AM   #48
Originally Posted by Srsci View Post
Thanks,
You said there was no picture of the pilot.
Here is the spec sheet from the model in question
http://icpindexing.mqgroup.com/docum...4108100100.pdf
hvaclover is offline   Reply With Quote
REZNOR gas shop heater WHOOMP ! on ignition Wildcat355 HVAC 14 01-29-2010 06:57 PM
GMP100-3: No ignition thelazydogsback HVAC 2 04-28-2009 11:13 PM
This may help someone with carrier ignition problems AweMan HVAC 15 02-09-2009 02:20 PM
furnace ignition troubleshooting buju HVAC 22 01-14-2009 11:41 PM
'93 Comfortmaker RPJ propane furnace lifespan? Dawsonhope HVAC 5 11-21-2008 06:47 AM
