Comfortmaker Furnace Won't Light - HVAC - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 11:29 AM   #1
Comfortmaker furnace won't light
I have a comfortmaker Enviro 90 propane furnace which won't light. The igniter is glowing, but it sounds as if the gas valve isn't opening. How do you trouble shoot this?
robnatrain is offline   Reply With Quote
Old 03-21-2012, 11:41 AM   #2
how
Rewards Points: 1,104
Check what the diagnostic led light is flashing.
Usually the first thing would be to check if the gas valve is getting 24 V when the HSI is glowing. Do you hear the gas valve click (to open) when the HSI is on?
Are your other gas appliances working?
how is offline   Reply With Quote
Old 03-21-2012, 12:27 PM   #3
lol..is the tank full and the LP turned on at furnace?
First thing is check for 24 v at valve while ignitor glows.
A little trick I use is lighting the burners with a Bar B Que lighter.
But you must be very careful.
hvac5646 is offline   Reply With Quote
Old 03-21-2012, 02:41 PM   #4
HVAC Tech/Owner
Rewards Points: 604
Careful is right, especially with propane......there was a tech here a few years ago that used that method and did not know there was a leak.....He spent a long time in the hospital from the burns and he's lucky to be alive.
Technow is offline   Reply With Quote
Old 03-21-2012, 03:40 PM   #5
He couldn't smell the LP?
If he didn't check for leaks or didn't realize that there was enough gas in the air to burn him like that, then he was one careless cuss.
Old 03-27-2012, 10:33 AM   #6
Yes guys the tank is full our stove works just fine. To check the voltage, there are 4 wires going to the control. Which is the hot and which is the neutral. The colors black, white, orange and blue. I know in tpical wiring diagrams black is the feed/hot wire and white is the neutral. They all run to a circuit board. Where can I get a schematic with out forking out $30.00 or so. Yea I am a tight wad in some ways. Any help you can give would be appreciated.
Old 03-27-2012, 12:00 PM   #7
HVAC Tech/Owner
Rewards Points: 604
Propane is heavier than air, it was down near the floor. Call was furnace not lighting.
Old 03-27-2012, 12:28 PM   #8
you have a smart valve, I believe.
gimme a model...I'll look it up for you. I do ICP furnaces.
The Following User Says Thank You to hvac5646 For This Useful Post:
robnatrain (03-27-2012)
Old 03-27-2012, 01:21 PM   #9
Thanks, here is the info. Furnace is a Comfortmaker Enviro 90 model #GNK075N1443, serial #L9936 45 047, the gas valve is a Honeywell SV9501M2726/24 volt. Thanks for the help!
Old 03-27-2012, 02:08 PM   #10
It's your gas valve.
Old 03-27-2012, 02:41 PM   #11
Where is the best place w/reasonable prices for a gas valve?
Old 03-27-2012, 02:59 PM   #12
check the net. ain't cheap. i buy my parts locally.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Gas furnace brands, which is better, Comfortmaker, American Standard, and Lennox? abefroman HVAC 10 04-22-2014 06:03 PM
Furnace will light - if I hit it! Chuch HVAC 1 10-28-2011 02:05 PM
Bryant 394G Furnace Pilot light problem rcgiii HVAC 0 03-05-2011 12:25 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
