Old 03-27-2006, 02:15 AM   #1
Comfortmaker furnace problem
I'm totally stuck on this one. I have a 12yr old Comfortmaker RPJ2. It was blowing cold air, so I replaced the thermostat, and had a company in to look at it. Apparently, it was so dirty, it was overheating and shutting down, leaving the fan blowing cold air. Ok, fine... They replaced the "high limit" (sensor?), and the flame sensor, and we had the furnace and vents cleaned. It worked fine for 3 days... Now it seems to intermittently blow cold air again. The only way to get heat again is to shut the heat of at the thermostat, then turn it back on again. Diagnostic is usless. No flashing lights, nothing.. We had the repair guys come back, and he couldn't find anything wrong with it. (Of course, it worked fine when he was here... figures..) I've already spent over $900 on this fiasco, and I still have the same problem as I started with. Any ideas?
dragon2125@hotmail.com is offline   Reply With Quote
Old 04-02-2006, 03:14 AM   #2
sub-contractor
too many ideas to list.
try reading some previous no heat posts. take a look at what the furnace is doing as far as its mode of operation when the problem arises.
does the inducer motor turn on?
does the ignitor glow or spark?
do the burners fire?
how long do the burners stay lit before shutting off?
this info will help me to answer your question.
Ace
Aceinstaller is offline   Reply With Quote
Old 12-07-2008, 02:12 PM   #3
Since the problem was masked when you had the service tech out, I must assume it works most of the time. It sounds like it doesn't ligh some times and goes through tree tries and fails, causing the furnace fan to come on and the ehat to go off. If it is a 90% furnace check the grommett located ont he wires going up to the hot surface ignition. If it's bad take a littleplumbers putty and fill in around the wires. Let me know if it's not a 90% furnace and I'll continue to work the problem.
Larry pickeringtonHVAC.com
lrfllc is offline   Reply With Quote
More On This Topic
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Hi I’m Anna from annawillowglassdesign.30art.com and I am going to show you how to make a Christmas ornament now out of blown glass. First I will gather a little bit of molten clear glass out of the furnace onto the end of the blow pipe and then I... Read More »
Hello, I'm Mark Blocker with Expert Village. In this segment were going to cover the heating and cooling system. In many of today?s new automobiles they have an air bypass valve installed on the cooling system. As I described before there is a thermostat... Read More »
Everyone can benefit from using less energy in their homes. You save money each month on your power bill, plus you have the happy knowledge that you are helping the environment by making your home more energy efficient. If everyone did a few energy... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Heil Furnace Burner Problem timothyr HVAC 65 10-26-2009 04:49 PM
New High Efficiency Furnace Problem Buster 567 HVAC 3 12-07-2008 02:05 PM
Comfortmaker furnace problem Big Red HVAC 11 02-10-2008 06:56 PM
furnace problem captjack HVAC 8 11-23-2007 12:15 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 03:04 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
