Old 06-05-2010, 11:04 AM   #1
comfortmaker furnace; i've done the hard part by taking the blower motor out
so i've been searching online and i'm not entirely convinced that i'll be ordering the right motor. I believe my motor is the culprit when the fan is on it makes a horrible sound like its trying to eat its way out of the furnace. after taking the entire assembly out of the housing i disassembled the motor from the rotating fan and pulled it out....there is oil/grease on part of the motor thats was closest to the ground. the fan doesnt look like its hitting anything so it definently looks like its the motor.
how do i go about making sure i have the right one? i have plugged in the model number and i get a bunch of hits but i see a lot of universals and I know that will be a pain to get the wiring correct. i just want to get a plug and play blower motor....is that even possible.
the model is of furnace is:
ComfortMaker
80+ single stage category I furnace.
N/8MPN/L
blower motor model is:
GE Motors
5KCP39NG
HP 1/2
RPM1050/4SPD
i can post a pic of the label of the blower motor if it would help. i need to buy this thing ASAP. its hot as hades durung the day in the house.
thanks in advance.
Hurell is offline   Reply With Quote
Old 06-05-2010, 11:10 AM   #2
i think this is e one but i dont see the wires coming off of it that i need to hook it back up to the circuit board, do all of the a replacements have the same wiring
Old 06-05-2010, 02:03 PM   #3
An old Tradesmen
No, many are 3 speed. And they may need a different sized capacitor.
Your furnace model number you posted. Is not the whole model number.
But any 1050 or 1075 RPM motor of the same frame and shaft size will work,. Make sure its the same amp draw and voltage.
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 10:01 AM
Carrier air handler blower part pwrengineer HVAC 8 04-16-2011 01:42 PM
Comfortmaker furnace problem Big Red HVAC 11 02-10-2008 06:56 PM
Replace a furnace blower motor dadncharge HVAC 2 12-06-2007 10:42 PM
Furnace Problems? Part 2 MCSE HVAC 9 11-30-2006 10:25 PM
