Comfortmaker Furnace Does Nothing! - HVAC - DIY Chatroom Home Improvement Forum
Old 04-28-2012, 10:43 AM   #1
comfortmaker furnace does nothing!
Comfortmaker furnace model GNK125N20A3 will not do anything. I cannot get 24V out of the transformer. There is 120V coming out of the circuit board, but no 24V on the secondary. I can disconnect the transformer from the circuit board and wire it to a direct 120V source and then I have 24V secondary, but when I connect it back to the board I have nothing. I repalace the circuit board and transformer and still have the same problem. Nothing runs or hums. Any other suggestions?
earl65 is offline   Reply With Quote
Old 04-28-2012, 10:52 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Is there a fuse on the board?
So you've got 120 volts going INTO the board via the door switch? Where is 120 volts coming out of, which terminal and to where is it going? A fan relay?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-28-2012, 12:37 PM   #3
Rewards Points: 582
you need to check the 120 volt going to board..including the netural,,, if you changed board and have same thing...has to be power going to board.........as a side thought is the new board wired up right.....had to ask .....
Old 04-28-2012, 01:47 PM   #4
Rewards Points: 614
poat a picture.... I just had a call on that furnace this winter with same problem... it was a connector somewhere .... picture may remind me....
carmon is offline   Reply With Quote
Old 04-28-2012, 02:14 PM   #5
Can someone please explain to me how to "poat a pitter?"
Ah grief, I crack me up.
Thanks.
Old 04-28-2012, 02:38 PM   #6
Yes, there is 120V going into the board and 120V at the transformer terminals, but when I plug in the transformer I loose the voltage. Thanks.
Old 04-28-2012, 02:43 PM   #7
Yes, there is power to the board and wired correctly and power at the transformer terminals, but with transformer plugged in it looses power to the transformer. Thanks.
Old 04-28-2012, 03:25 PM   #8
An old Tradesmen
Rewards Points: 6,132
Sounds like a bad connection somewhere between the breaker panel and the control board.
Old 04-28-2012, 06:31 PM   #9
Rewards Points: 614
oh man .... I had to laugh at that to... getting old....
Old 04-28-2012, 06:38 PM   #10
Rewards Points: 614
what do you mean by transformer plugged in..... you have 24 volts with the secondary not connected.... then if you connect the secondary you loose the 24 volts on the terminals where you had 24 volts before... I am not quit sure how that would be possible... its got me thinking
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Comfortmaker furnace issues Ken1213 HVAC 1 11-12-2011 12:09 PM
tiling under new furnace gramps416 Flooring 4 01-09-2011 11:47 AM
Comfortmaker Furnace GUH075A012IN Jim123 HVAC 0 01-05-2011 07:32 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
