Comfortmaker Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2008, 10:58 PM   #1
I have a comfortmaker furnace model number GNE125J20AI. Just turned it on for the winter. The Pilot comes on as well as the blower motor but the burner unit doesn't ignite. Any Thoughts......
tmcdougall is offline   Reply With Quote
Old 10-08-2008, 04:25 PM   #2
HvacWiz's Avatar
Rewards Points: 252
Check for 24v at the gas valve on the call for heat with a meter.
HvacWiz is offline   Reply With Quote
Old 10-08-2008, 08:24 PM   #3
tHAT FURNACE HAS NO PILOT. IT HAS AN HSI (HOT SURFACE IGNITION).
Are you seeing a red glow when you turn it on?
hvaclover is offline   Reply With Quote
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 04:22 PM
Comfortmaker furnace problem dragon2125@hotmail.com HVAC 2 12-07-2008 02:12 PM
'93 Comfortmaker RPJ propane furnace lifespan? Dawsonhope HVAC 5 11-21-2008 06:47 AM
Comfortmaker furnace problem Big Red HVAC 11 02-10-2008 06:56 PM
Comfortmaker furnace Duane HVAC 4 03-23-2007 10:58 AM
