Comfortmaker Blower Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 08:00 PM   #1
Comfortmaker blower problem
Comfortmaker blower intermittent problem
I have a 1990 SnyderGeneral Model #GUA100 Comfortmaker furnance that has developed a problem. The blower will not start when the furnance heats up. The furnance will ignite and simply runs and runs, but the blower will not start. The blower has been replaced but this still has not corrected the problem. Recently when the furnance has been runing I manually switched the fan on at the thermostat. While the fan is running the blower starts a few minutes later. I switch the fan off and most of the time the blower continues until the furnance has heated to the setting temperature. When the furnance trys to recyle again the blower will not start and I have to manually start the fan again.
At no time does the error light come.
Any help, and all suggestions, are greatly appreciated.
Rerobins
rerobins is offline   Reply With Quote
Old 01-05-2010, 10:39 PM   #2
An old Tradesmen
Rewards Points: 7,764
Might have a weak capacitor. Was it changed when the motor was changed.
Old 01-06-2010, 10:38 AM   #3
Could be a weak capacitor, but the motor uses the same capacitor for hi speed (fan on) and heat (low speed).
If you can force the fan on at the t-stat then I would suspect the fan relay.
Does this unit have a fan/limit switch or a relay? Why was the blower replaced?
chard is offline   Reply With Quote
Lennox G12 Blower Motor Problem jimvh2 HVAC 15 03-19-2016 11:27 AM
Furnace will not stay on allenzachary HVAC 32 09-21-2010 08:30 PM
Carrier 58SX Main Blower Turns On Without Command otismyman HVAC 19 09-25-2009 07:06 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Question about air handler blower problem whlnut HVAC 2 08-27-2007 01:01 AM
