Old 10-27-2012, 06:17 PM   #1
Question
Comfort maker furnace won't start inducer motor.
I have a comfort maker gas furnace model c8mpn100f20a1. Inducer motor will not start to fire up the heat sequence. 24 v power supply is good, limit switches show 17v on all ends. There is no voltage on the wires to the inducer that comes from a plug on the gas valve sv9541. The main board has been replaced and does the same thing. Does this mean my valve is bad? How can I verify?
Jperez5 is offline   Reply With Quote
Old 10-27-2012, 06:49 PM   #2
I was just reading, on another post, that those smart valves, as designated by the sv in your valve number, fail often and that you could try wiggling the pin connector at the valve to see if the sequence will start.
That's all I can suggest right now. Hopefully some of the guys with more experience will provide input.
techpappy is offline   Reply With Quote
Old 10-27-2012, 07:26 PM   #3
jumper r to w on control board and see if it starts heat sequence...
Old 10-27-2012, 07:34 PM   #4
I jumped r to w and still no start. Checked the signal on w and signal is there from thermosthat.
Old 10-27-2012, 08:48 PM   #5
seems like you have a bad valve...here is a diagram... ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Jperez5 (10-28-2012)
Old 10-28-2012, 08:55 PM   #6
Is there any way I can make it run until my new valve comes in? I jumped the inducer motor and made it run, but the heat sequence never started.
Old 10-28-2012, 11:05 PM   #7
No there's not.
How to replace condensor fan motor? twags HVAC 41 09-13-2012 07:05 PM
York Diamond 90 furnace not starting items HVAC 14 12-23-2011 11:57 AM
Bryant Plus 90 398AAZ inducer motor PCWilson HVAC 10 02-27-2011 05:55 PM
Inducer motor had been squeaking OhDamn HVAC 5 12-17-2009 10:19 PM
Inducer motor or control circuit? Please help me troubleshoot. averagerob HVAC 1 03-03-2009 02:43 PM
