Comfort Maker - HVAC - DIY Chatroom Home Improvement Forum
Old 03-17-2009, 08:13 PM   #1
comfort maker
the induced draft motor runs when power is applied to furnace whether the thermostat is set above or below temp. in house. the igniter does not glow and the furnace control module is giving 2 flashes indicating pressure switch stuck closed, while the induced draft motor continues to run.
mnopytfbc is offline   Reply With Quote
Old 03-17-2009, 08:28 PM   #2
HVAC / Plumbing
probably circuit board unless you've wired up something wrong on the t.stat... I had this problem with a coleman. Inducer fan ran in summer when A/C was on. Replaced circuit board & it cured the problem
kenmac is offline   Reply With Quote
Old 03-17-2009, 08:31 PM   #3
the induced draft motor runs when power is applied to furnace whether the thermostat is set above or below temp. in house. the igniter does not glow and the furnace control module is giving 2 flashes indicating pressure switch stuck closed, while the induced draft motor continues to run. if i pull the hose from the induced draft motor that goes to the pressure switch it indiates 3 flashes indicating pressure switch stuck open. putting hose back on and then the furnace operates like it should. after running through cycle the induced draft motor continues to run and i have to shut power of to furnace. this is the only way i can get heat in my house.
Old 03-17-2009, 08:32 PM   #4
With the fan going the pressure switch is supposed to be closed unless you have a certain model.
Post model # and if it is a 80 or 90% furnace.
hvaclover is offline   Reply With Quote
Old 03-17-2009, 08:43 PM   #5
model#gni080a012cin fan doesnt want to shut off whether thermostat is set above or below the temp. in house
Old 03-17-2009, 08:44 PM   #6
HVAC / Plumbing
Turn t.stat to the off position ...See if the motor still runs... Try A/C see if it still runs
Old 03-17-2009, 09:28 PM   #7
An old Tradesmen
Rewards Points: 6,540
Stuck relay.
Old 03-17-2009, 10:10 PM   #8
GC/Master Plumber/Mech
Rewards Points: 560
Originally Posted by beenthere View Post
Stuck relay.
Amen,
Turning off stat won't solve a thing. Open up the lower door access to the control board and using a non-conducting device, lightly tap on the control board and whal'la the inducer will go off.
Old 03-17-2009, 11:07 PM   #9
Deep thoughts:
Since passenger trains have conductors, do they have to be NEC approved?
Old 03-17-2009, 11:19 PM   #10
HVAC / Plumbing
Get a board your way . if it's the relay.Chances are it will stick again.
Old 03-18-2009, 03:28 AM   #11
than you very much
1998 Comfort Maker RPJ11 furnaceman HVAC 1 01-11-2009 10:34 AM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
Ice Maker problem. sflamedic Appliances 5 08-25-2008 06:28 AM
