Comfort Breeze E1 - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2013, 08:52 PM   #1
comfort breeze e1
error1 I have this problem on a 24 cbr cbz comfort q quarrel may be.
electrico is offline   Reply With Quote
Old 09-10-2013, 08:47 AM   #2
Rewards Points: 77
Kind of difficult to figure out what you are asking but I believe you are saying you have an error 1 on your Comfort Breeze. I believe that is an indicator that you need to clean/change your air filter.
After cleaning the filter, try this:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan and compressor each come on briefly, etc). There should be a "beep" sound at the end of the test sequence and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
firedawgsatx is offline   Reply With Quote
Old 09-10-2013, 06:28 PM   #3
Thanks for your prompt reply. my mini splits have no power bottom that I can do?
Old 09-10-2013, 08:01 PM   #4
Rewards Points: 77
Can you give us more information as far as the exact make/model of your mini-splits?
Old 09-10-2013, 08:22 PM   #5
comfort breeze cbz 24cbr
Old 09-10-2013, 09:49 PM   #6
Rewards Points: 77
I can't find any literature based on that model number. Do you have the owner's manual? There should be a list of error codes in there and the probable cause of the error.
Old 09-11-2013, 07:39 PM   #7
Rewards Points: 77
Sometimes turning the breaker off and then back on will "reboot" the system just like a reboot of a computer. It is worth a try.
Old 09-11-2013, 10:39 PM   #8
http://www.ccairconditioning.com/hom.../CBZ_front.pdf
Carrier Comfort 95 Question acerunner HVAC 0 06-03-2011 02:35 PM
Carrier comfort zone II upgrade from comfort zone question detyianni HVAC 3 11-30-2010 01:27 PM
Controlling a Carrier Comfort Zone II with a PC masterchief General DIY Discussions 0 08-30-2010 12:39 PM
Modifying Grundfos Comfort Series Instant hot water recirculator Mike Warner HVAC 3 03-01-2010 12:08 PM
Lock Tab installation for Harbor Breeze Fan Andy B General DIY Discussions 0 02-06-2010 01:12 PM
