-   -   comfort breeze e1 (http://www.diychatroom.com/f17/comfort-breeze-e1-186702/)
electrico 09-08-2013 08:52 PM
comfort breeze e1
error1 I have this problem on a 24 cbr cbz comfort q quarrel may be.
firedawgsatx 09-10-2013 08:47 AM
Kind of difficult to figure out what you are asking but I believe you are saying you have an error 1 on your Comfort Breeze. I believe that is an indicator that you need to clean/change your air filter.
After cleaning the filter, try this:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan and compressor each come on briefly, etc). There should be a "beep" sound at the end of the test sequence and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
electrico 09-10-2013 06:28 PM
Thanks for your prompt reply. my mini splits have no power bottom that I can do?
firedawgsatx 09-10-2013 08:01 PM
Can you give us more information as far as the exact make/model of your mini-splits?
electrico 09-10-2013 08:22 PM
comfort breeze cbz 24cbr
firedawgsatx 09-10-2013 09:49 PM
I can't find any literature based on that model number. Do you have the owner's manual? There should be a list of error codes in there and the probable cause of the error.
firedawgsatx 09-11-2013 07:39 PM
Sometimes turning the breaker off and then back on will "reboot" the system just like a reboot of a computer. It is worth a try.
electrico 09-11-2013 10:39 PM
http://www.ccairconditioning.com/hom.../CBZ_front.pdf
