Comfort 92 Code 31 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-24-2011, 08:45 AM   #1
comfort 92 code 31
carrier comfort 92..code 31...which is pressure switch code...i replace pressure switch with known good switch..same problem..i removed cover for burners, furnace fired up...replaced cover, furnace will not light..removed pvc pipe from air intake combustion chamber, furnace will light..checked and double checked air intake pvc tubing end to end, no obstructions..all other tubing seems to be clear and open..what else could be the problem of not closing switch (normally Open)...here is pic of unit
By gatorchin75 at 2011-12-24
gatorchin is offline   Reply With Quote
Old 12-24-2011, 08:49 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Did you clear the ports where the tube connects? The draft inducer may be bad.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-24-2011, 08:59 AM   #3
yes..i removed blower assembly and checked all ports..inducer motor seems to be turning fine.(to my inexperienced eyes)...only when i open something up like the burner cover or remove pvc from intake chamber, everything runs fine.
Old 12-24-2011, 09:16 AM   #4
Your intake pipe is clogged.............
harleyrider is offline   Reply With Quote
Old 12-24-2011, 09:19 AM   #5
Flue pipe might be obstructed..? Btw, inducers can run but when they get weak they don't run well or as strong and will not close a pressure switch.
Check for an obstructed flue pipe, make sure it's clear all the way through the roof.
Thanks.
Old 12-24-2011, 09:19 AM   #6
and what Harley said.
Thanks.
Old 12-24-2011, 09:23 AM   #7
Houston204's Avatar
Rewards Points: 556
A pressure switch lockout can also be a plugged condensate drain.
Houston204 is offline   Reply With Quote
Old 12-24-2011, 09:27 AM   #8
Yes thats correct, but as the customer stated in his first post, he takes the burner door off, and it runs fine. In my 30 + years the most important thing I have learned is to listen to everything the customer says and then diagnose and draw a conclusion. If it was a drain issue, removing the burner door would not cure the problem.
Old 12-24-2011, 09:28 AM   #9
doc and harleyrider...i figured intake was clogged somewhere as well...so when i removed pvc from air intake combustion chamber, i went ahead and cut the pipe where you can see the black rubber coupling in the pic..everything was clear...from the cut to the other end of the piping is just about two feet, (it runs out the side of building, why they didnt go straight up i dont know)..you can see in the pic the intake and exhaust runs together...kind of..the intake is the 4" pipe, with a 2" pipe inside it for the exhaust..there is a cap on the outside that is supposed to separate the two..anyway, i checked the intake all the way outside..clear as it can be..
Uploaded with ImageShack.us
Old 12-24-2011, 09:30 AM   #10
checked condesation drains..all clear
Old 12-24-2011, 09:30 AM   #11
what about right above the burner box? there is a screen in there that can catch leaves and debris.
Old 12-24-2011, 09:32 AM   #12
Houston204's Avatar
Rewards Points: 556
Are there ang sags in the vent pipe that may be holding condensation?
Old 12-24-2011, 09:34 AM   #13
are you talking about the screen in the air intake combustion chamber??(black plastic box on top of burner box)?? if so yes, i removed this component and it was clear of any obstructions
Old 12-24-2011, 09:37 AM   #14
how old is this furnace?
Old 12-24-2011, 09:38 AM   #15
when i cut the intake pipe, i taped a rubber glove over the opening and put a small hole in the glove...used air compressor to blow out the pipe..when i did this i did see a small amount of dirty water droplets leaking back down the pipe...now was this from air compressor or the pipe itself?? i don't know..after blowing it out i visually inspected and could not find any dirt or debris, although it was raining outside..i then put everything back together and still would not light unless i removed burner cover or intake piping...i know this all indicates a clogged intake, but for the life of me it looks clear
Carrier Furnace Error Code 34 Comfort 80 bamsgl HVAC 5 12-30-2011 09:08 AM
Carrier Comfort 92 LED code 31 superape HVAC 2 12-04-2011 06:07 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
Finding a copy of the 2006 International Building Code WFO Electrical 2 07-11-2009 07:21 PM
