Comformaker Oil Furnace....Biodiesel Compatable? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2008, 06:46 PM   #1
Comformaker Oil Furnace....Biodiesel compatable?
I have a comformaker down flow horizontal oil fired furnace with a Beckett RWB AFG oil burner and a honeywell ignition system....it normally runs on diesel and I recently put biodiesel into the tank and it seems to be struggling...does anyone have any feedback on this process? Single mom in "family" house without a whole lot of experience in this area....help!
lizabeth is offline   Reply With Quote
Old 12-14-2008, 06:52 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
That may be a big problem. Modern high efficiency oil burners are very highly tuned units and require the proper fuel they were designed for. Yours may be plugging up the nozzle or even worse may not be burning cleanly and plugging up the furnace with soot. I would get a servicetech in soon to find out what is going on. You may need a fresh batch of diesel. Sorry.
Old 12-14-2008, 07:25 PM   #3
Thanks for your input...I will get a tech to come and check it out...much appreciated.
Old 12-15-2008, 06:28 AM   #4
Mainah's Avatar
Last I knew Beckett has not approved biodeisel as a fuel source- There was talk of a 5% blend but only on select models
Make sure you tell the tech whats in your tank, I'm afraid your likely going to have to drain your tank and put the proper fuel in-
Mainah is offline   Reply With Quote
Old 12-15-2008, 05:37 PM   #5
An old Tradesmen
Rewards Points: 6,500
Yea.
That bio, may be cleaning your tank.
Which plugs the filter, strainer, and nozzle.
And may do so, for some time to come.
Old 12-15-2008, 08:21 PM   #6
Hvac Pro
yuri's Avatar
From what I heard that stuff is made from the awful oil McD's uses to cook our fries and plug our arteries. Poor furnace.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Comformaker gas furnace ignites but blowe wont come on China HVAC 12 01-03-2013 08:09 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
