-   -   Comformaker Oil Furnace....Biodiesel compatable? (http://www.diychatroom.com/f17/comformaker-oil-furnace-biodiesel-compatable-33752/)
lizabeth 12-14-2008 06:46 PM
I have a comformaker down flow horizontal oil fired furnace with a Beckett RWB AFG oil burner and a honeywell ignition system....it normally runs on diesel and I recently put biodiesel into the tank and it seems to be struggling...does anyone have any feedback on this process? Single mom in "family" house without a whole lot of experience in this area....help!
yuri 12-14-2008 06:52 PM
That may be a big problem. Modern high efficiency oil burners are very highly tuned units and require the proper fuel they were designed for. Yours may be plugging up the nozzle or even worse may not be burning cleanly and plugging up the furnace with soot. I would get a servicetech in soon to find out what is going on. You may need a fresh batch of diesel. Sorry.
lizabeth 12-14-2008 07:25 PM
Thanks for your input...I will get a tech to come and check it out...much appreciated.
Mainah 12-15-2008 06:28 AM
Last I knew Beckett has not approved biodeisel as a fuel source- There was talk of a 5% blend but only on select models
Make sure you tell the tech whats in your tank, I'm afraid your likely going to have to drain your tank and put the proper fuel in-
beenthere 12-15-2008 05:37 PM
Yea.
That bio, may be cleaning your tank.
Which plugs the filter, strainer, and nozzle.
And may do so, for some time to come.
yuri 12-15-2008 08:21 PM
From what I heard that stuff is made from the awful oil McD's uses to cook our fries and plug our arteries. Poor furnace.
