-   -   Comformaker gas furnace ignites but blowe wont come on (http://www.diychatroom.com/f17/comformaker-gas-furnace-ignites-but-blowe-wont-come-33009/)
China 12-02-2008 09:46 AM
My 10 old Comfortmaker gas furnace ignites and little fan works outside but main blower does not come on. I called my repairman...I have seen him deal with this a time or two over the years but I forgot. I know he removes the panel door but thats it!!! I am so afraid of gas. Can anyone tell me exactly whats NOT happening and how I can maybe make the fan come on? :no:
hvaclover 12-02-2008 10:01 AM
Possible blower control.
Try switching the the "Auto_ON" selector to to the "ON" position and see if the blower comes on.
Other wise the run cap or motor could be bad.
China 12-02-2008 10:23 AM
Tried that first thing...........nothing! Thought maybe there was a way to turn the blower on manually until...repairman calls me back. I havent spoken to him yet just left a message~
hvaclover 12-02-2008 10:30 AM
If the inducer fan comes on as you stated and the furnace fires, than it's either a control board, motor or run cap.
spiritseeker 12-18-2008 09:17 PM
I have a similar problem, when I switch from auto to fan the blower does come on. The furnace fires up but the fan does not come on in auto mode, then the furnace shuts down. Blower works fine in fan mode and eventually blows cold air once the furnace shuts off. Can anyone help diagnose this?
MarshallDylan 12-22-2012 07:45 PM
It may be a stuck fan limit control switch spring.
My Comfort Maker gas furnace had the very same symptoms, and I just fixed it. My problem was caused by a stuck fan limit control switch spring. This spring expands when the furnace heats up, rotating a dial which switches on the blower fan. To get to mine, I first switched off the power to the furnace. Then I took off the topmost removable panel (the one with horizontal vent holes in it) and sttoping down so that I could peer at the very top of the interior, I saw a metal box with "Honeywell" imprinted on it about 2" x 4" in size. This was the fan limit control switch. I removed it's cover and rotated the dial back and forth multiple times to loosen the stuck spring, then replaced the cover and turned back on the power to the furnace. I am now enjoying heat! This is very easy to do and only takes a few minutes. If this does not work, you may need to replace the fan limit control switch. The part number is written on the side of it, and may be ordered on eBay. To replace, just unscrew the retaining screws and unplug the wiring harness. Make sure the dial settings on the new switch are set the same as your old one first, though.
hvac5646 12-23-2012 07:08 AM
Originally Posted by MarshallDylan (Post 1078269)
My Comfort Maker gas furnace had the very same symptoms, and I just fixed it. My problem was caused by a stuck fan limit control switch spring. This spring expands when the furnace .....
You just described a worn out fan-limit control that needs replacement.
Also, you have a very old furnace if you have a "spring" in the fan-limit control....better make sure you didn't ruin the control by turning it....moving control manually over stretches the "spring".
how 12-23-2012 04:19 PM
That fan/limit control actual has a warning stamped on the dial not to do what you did.
If turning it didn't put it out of calibration, then it just stopped that bimetal spiral strip spring from binding on something which is still there.
In my experience that is just a very temporary fix. The good news is it's not an expensive or hard part to change.
danpik 12-23-2012 07:04 PM
Marshall. You do realize you dredged up a 4 year old post. I am sure the original poster has it fixed properly by now
hvac5646 12-24-2012 06:38 AM
MarshallDylan "dredged it up"....the information he posted needed to be corrected.
Don't want other people with furnaces that age rendering the only safety (or just about the only one) that furnace has inoperable.
Reminders of solid safety and correct service procedures are never out of date.
MarshallDylan 12-26-2012 03:05 PM
I am not an HVAC profesional, so I very much appreciate your safety precautions, and urge all readers to follow your advice in this matter. My furnace is still working fine, but in light of your comments, I can see why the procedure I followed could potentially be dangerous, or may only be a temporary fix. Better to play it safe, and simply replace the fan limit control switch if you have a unit like mine.
apv1981 01-03-2013 09:39 AM
Blower on Comfortmaker RPJ II
Hi,
I am having the same problem and would appreciate some advice.
The Blower of my 1993 Comfortmaker RPJ II will not come on when thermostat calls for heat. Blower comes on when thermostat is set to "ON". If i then turn thermostat to call for heat with blower in the "On" position the blower shuts off in a under a minute and then the burners go out too after a few seconds. The control board then flashes four times which indicates a 'Open high limit switch'.
Technician who came out to look at it think the board is fried and wants 600$ to replace it. He then hooked up the blower directly so that it is always running and thermostat calls for heat when it needs to.
Hoping for some suggestions to identify which part is causing the problem.
MarshallDylan 01-03-2013 07:09 PM
[quote=apv1981;1085231]Hi,
[\quote]
You could try replacing the fan limit control switch. That was the culprit when my system had the very same symptoms.
