Combustion Fan Making Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 12:23 PM   #1
combustion fan making noise
the combustion fan on our comfortmaker is out of wack and the fins of the fan blade rub on the furnace or fan housing. they dont sell just the fan, you have to buy the whole assembly. i fixed it a couple of years ago by using a screw driver to bend the blades with out taking it apart. does anyone know ant other ways to fix this?
Mike18 is offline   Reply With Quote
Old 11-30-2011, 12:50 PM   #2
Originally Posted by Mike18 View Post
the combustion fan on our comfortmaker is out of wack and the fins of the fan blade rub on the furnace or fan housing. they don't sell just the fan, you have to buy the whole assembly. i fixed it a couple of years ago by using a screw driver to bend the blades with out taking it apart. does anyone know ant other ways to fix this?
Since that assembly is responsible for removing the by products of combustion, a potential deadly gas....the ONLY sensible thing to do is to replace the entire assembly, as well as any gaskets that go with it. Any one who advises you differently would be ill advised to do so.
harleyrider is offline   Reply With Quote
Tags
combustion fan , comfortmaker
Hot Water Pipes Making Noise kubichekb Plumbing 2 02-12-2010 10:41 AM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 11:25 AM
New Rheem 90+ is making a strange noise. Draft inducer? shinkansen HVAC 1 01-09-2009 08:38 AM
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 02:45 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
