Combustion Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 07:59 AM   #1
combustion fan
I have a furnace about 15 years old. the combustion fan from time to time will keep cycling on and off and could go on for hours. If I raise the temp. on the thermostat the burner light up and I have heat. Problem goes away for awhile then it starts again. What would cause this to happen
ReneLM is offline   Reply With Quote
Old 03-25-2011, 08:04 AM   #2
Experienced
Jackofall1's Avatar
Hi and Welcome ReneLM, to the best DIY'r site on the web.
Sure sounds to me like your thermostat is not set with enough hysteresis.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
ReneLM (03-25-2011)
Old 03-25-2011, 08:07 AM   #3
HVAC / Plumbing
short in the board ? Disconnect the t.stat wires & leave them off for a while & see if the motor turns on
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
ReneLM (03-25-2011)
Old 03-25-2011, 05:21 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 402
Did you replace your thermostat recently. The cheap power stealing types can cause your problem. I would replace the thermostat with a good quality Honeywell Focus Pro from HDepot.
Old 03-26-2011, 02:54 AM   #5
how
Rewards Points: 1,104
Jackofall1
For the benefit of this dinosaur, is thermostatic hysteresis the electronic equivilent of anticipator settings?
how is offline   Reply With Quote
Old 03-26-2011, 04:54 PM   #6
Experienced
Jackofall1's Avatar
Originally Posted by how View Post
Jackofall1
Yes, exactly, the differential between the off and on, or the overlap.
Mark
Replacement Combustion chamber kit OK? safety1st HVAC 13 02-28-2011 09:14 PM
Intermittent furnace lockouts, fouled nozzles, combustion air, and cold basements rodney23 HVAC 6 02-13-2011 09:38 AM
Testing combustion on 95% furace? okrite HVAC 8 01-07-2010 09:58 AM
Combustion (make-up) air in basement tthacke HVAC 10 12-30-2008 12:07 PM
Trane xl90 Combustion blower Issues bjpaff HVAC 3 12-18-2007 10:00 PM
