Combustion Air Grills Near Supply Vent? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-09-2011, 02:04 PM   #1
Rewards Points: 302
combustion air grills near supply vent?
Hey all,
Wrapping up my basement finishing project. Total square footage of the entire basement exceeds by a good bit the total cubic square feet of combustion air required per total BTUs of my HWH and HVAC.
These units sit it what was once a hall and are open to a 12x12 storage room. That storage room has a door. On the other end is drywall. I'm going to be putting large high and low grills in that drywall and also one lower in that door. I figure I don't need high/low in the door as well.
So effectively, with these grills, the entire basement is one big open space for combustion air for the units.
However, on the drywall side - there just happens to be a supply vent very near where I'd want to put the high grill. The supply is in one stud-cell - and the most logical and nicest looking spot for that high grill is in the next stud cell - mere inches from the supply vent.
I don't know how much combustion air those units suck in. But I'd hate to negate the coinditioned air coming out that supply vent by having it get sucked right back into the combustion air grill. I know combustion air openings aren't like return vents, so not like a vacuum.
So - does it matter how close the grills are to a supply vent? My only other option is about 5 feet further away.
denemante is offline   Reply With Quote
Old 05-09-2011, 02:29 PM   #2
Not a problem. Combustion air from inside isn't drafty so it wont rob your supply. It's just allowing oxygen to get back to the fire.
Old 05-09-2011, 03:22 PM   #3
Rewards Points: 302
Thanks!
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 09:48 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 02:39 PM
Supply vent exiting on other side of shared wall? pmandra1 HVAC 1 07-29-2010 08:03 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
