Combustion Air Fan On My Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 09:53 PM   #1
Rewards Points: 20
Combustion air fan on my furnace
The combustion air fan on my furnace has jammed up. When I put the heat on, an electric hum is all I get until I go to the furnace and spin the fan shaft with my hand to get it going. Then the furnace works as normal.
Is it worth cleaning the fan, or should I just replace it?
When I tried to take it off, there were three obvious screws that I unscrewed, but the fan, though very loose, did not come out. Is there a trick to it?
As I'm not much of a DIYer, I'm also wondering if this is the kind of job I should attemp. Maybe get a pro?
My furnace is a Lennox G50UH 24A-070-03
Thanks...
BCSapper is offline   Reply With Quote
Old 06-27-2011, 05:52 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,230
I would get a Lennox tech to do it. Quite complicated with 2 gaskets to hold in place and the replacement is a retrofit and needs a different pressure switch with it. Fan and motor come as a unit.
Old 06-27-2011, 08:20 AM   #3
Rewards Points: 20
Thanks for the prompt reply. I will do just that.
Old 02-14-2014, 09:52 AM   #4
Combustion fan noisy - Lubrication?
The combustion chamber fan just started making noise. Sounds like a bearing is failing or needs lubrication.
Do I need a new fan assembly or can I remove it and lubricate it?
furnjd is offline   Reply With Quote
Old 02-14-2014, 12:46 PM   #5
Hvac Pro
yuri's Avatar
has sealed bearings so you need a new unit.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Intermittent furnace lockouts, fouled nozzles, combustion air, and cold basements rodney23 HVAC 6 02-13-2011 09:38 AM
furnace combustion air from attic rvegab00 HVAC 3 12-07-2009 08:18 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
