Combstion Air Inducer Water Problems On Lennox G61mpv - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 12:45 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
No, the inducer is made from plastic and if it had a hole then lots of water would be leaking. The rusty water ran down the inducer from behind and is very small and normal. Unless you can post a CLEAR sounding recording of the sound then I cannot tell what it is. 100% of the inducers I replace if they are noisy will do it all the time when running so it sounds a bit suspicous that yours only does it on startup but anything is possible. I have worked on thousands of those units (very popular seller) and there have been no problems like yours but anything is possible.
Old 03-28-2013, 04:19 PM   #17
Rewards Points: 610
YURI..pardin me for interrupting. Just wanted to thank you for the info....I live in a small village with a small lot so, geo thermal not feasible..mid Ontario so, quite often get minus 15 C but will do more research before I do anything. 25% savings will take 6 years to pay back. THANKS AGAIN
Techpappy
techpappy is offline   Reply With Quote
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Lennox G61 quote, also water heater and ac bw77 HVAC 1 06-16-2011 08:12 PM
HELP: Lennox C33-36C-2F leaking water hamproof HVAC 33 06-26-2010 03:48 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
